11-23-2015, 12:12 AM | #1 |
Tall tale signs of broken head gasket?
It looks worse in person, but I see my green coolant leaking on the left side above the push rod covers. At this point I'm considering paying for a full rebuild.... But what do you guys think I should do? Buy some head gasket stop leak for the time being? Pay for a rebuild or just replace the gasket?
11-23-2015, 12:13 AM | #2 |
Re: Tall tale signs of broken head gasket?
Along the head
11-23-2015, 12:14 AM | #3 |
Last one
11-23-2015, 12:16 AM | #4 |
Or could it just be a procedure of re-tourqing the head bolts and nothing serious? There isn't any oil in my radiator
11-23-2015, 01:23 AM | #5 |
Someone with experience please let me know
11-23-2015, 02:01 AM | #6 |
You said there's no oil in the radiator... please tell us you also checked and made sure there's no water in the oil? (It'll look like chocolate milk)
I just tried to do a head-gasket-only repair on a Dodge 400ci big block. It didn't last a week before it went again. If you've got a blown head gasket, you should have the head surfaced, and probably the block decked. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
11-23-2015, 08:47 AM | #7 |
Leaking head gaskets don't leak green fluid. It comes out dirty brown. That's because the coolant is mixed with fuel vapor or oil.
Clean that motor up so it's spotless, then find your leak. Likely coming from the front on the thermo housing. I had a thermo housing leak that showed up on the drivers side rear of the tranny. The coolant ran down along the top of the pan. |
11-23-2015, 10:11 AM | #8 | |
11-23-2015, 10:12 AM | #9 |
Oil
11-23-2015, 11:03 AM | #10 |
Clean it up good and pressure check it. An old head gasket can rot from the coolant passage to the outside. Clean oil and coolant just tells you it did not go bad in those directions. If it still runs good I would just put a head gasket on it after the pressure test.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-23-2015, 11:07 AM | #11 |
Post Whore
Pressure wash that engine and then run it and see where the leak is. If your Sure it leaks from the head after the wash then consider a rebuild or gasket. The oil and water look fine. Is that coolant under the oil line on the passenger side or Oil? lol The blue underneath distorts the color of the liquid there so I wondered if its oil leaking from the pressure line there?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-23-2015, 11:52 AM | #12 | |
11-23-2015, 11:56 AM | #13 | |
11-23-2015, 12:31 PM | #14 |
How do I do a pressure check?
11-23-2015, 05:07 PM | #15 |
My head gasket is definitely busted
11-23-2015, 06:07 PM | #16 |
Post Whore
Its hard to see in the picture, but what is all that white stuff by the oil pressure line? lol Silicon?
11-23-2015, 06:58 PM | #17 |
11-23-2015, 07:36 PM | #18 |
Does anyone know of an engine rebuilder near me in the Coachella valley?
11-23-2015, 08:36 PM | #19 | |
11-23-2015, 08:58 PM | #20 |
So to whoever is reading, the coolant seems to be coming out of the copper oil pressure line. I'm not sure what that means. I am saying this because while I was revving the motor I was watching the leak.
11-24-2015, 11:09 AM | #21 |
:UPDATE: to who ever is watching, that puddle is leaking from oil Pressure line, and I clean the edges around the head and it isn't showing any major leaks, two pin small areas that a little wet but I am not sure if that is anything serious. A maybe wrong on a head gasket leak, but I going to replace the line or possibly plug it and see where we go from there
11-24-2015, 11:47 AM | #22 | ||
"I ain't nobody, dork."
There could be a hair line crack in the block in the water jacket that is close to that fitting. I'm sure that's what all the goop is there for.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-24-2015, 11:59 AM | #23 |
11-24-2015, 12:04 PM | #24 | ||
Only way to tell if there is a crack in the block or in the head that you can't see with the naked eye, is to have them magnafluxed at a machine shop.
Gary
11-24-2015, 01:43 PM | #25 |
If coolant was coming out of that bad oil line fitting you would see it in the oiling system too. Definitely have the head checked for flat when it is off. Those I6 almost always show some warpage. And do replace the freeze plugs at that point. Don't want an old corroded one blowing coolant behind your manifolds later on.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
