Old 11-23-2015, 03:16 AM   #1
SonomaComa
How to identify the Rear End?
How do you identify a Dana 60 Rear End? I have a 1970 GMC C20 long bed with leaf springs in the rear. It has a 10 Bolt rear end. It is a Full Floater with 12" Drums. The Drums just SLIDE OFF, the Axles do not need to be removed to take off the Drums. It has 7 bolts attaching the Backing Plate to the Axle Housing. It is 8 Lug with 1/2" x20 Wheel Studs. Looking at the diff cover, on the passenger side, it has a code written upside-down C-30255, and below that it has the number 60. Is this a Dana 60 Rear End?
SonomaComa is offline   Reply With Quote
Old 11-23-2015, 06:50 AM   #2
JCD
JCD's Avatar
Re: How to identify the Rear End?
Here's a thread with pictures.
I have the same Dana 60 in my 1972
http://67-72chevytrucks.com/vboard/s...d.php?t=399360
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 11-23-2015, 08:54 AM   #3
That thread is mostly about front axles, but same center section. The last picture does show a rear. funny how GM corporate rears got named by number of bolts on differential cover (10-bolt/12-bolt) when that doesn't say squat. Just GM alone used four different rears that I can think of that had 10 bolts for the differential cover. And the Dana rears were found in GM, Ford, Dodge, IH trucks, Mopar cars, Jeeps, on and on
Old 11-23-2015, 07:47 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If it's peculiarly shaped it's Kim Kardashian's, if it's perfect it's Carla Gugino's? That's all I can offer.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
