Old 11-23-2015, 10:35 AM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
any way to tell what ratio rear?
I'm assuming my open end ,6 lug rear is a 4.10 or something? the truck was originally a 6 cyl with 3 speed. anyway to tell w/o opening her up. I know on a posi(that works) you can count the revs, but not on an open diff. thanx , crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 11-23-2015, 10:58 AM   #2
PGSigns
PGSigns's Avatar
Re: any way to tell what ratio rear?
99% were 3.73. There is a set of numbers stamped into the housing. Best thing to do is just pull the cover and take a look. This lets you know the true ratio and gets some fresh oil in it that most really need.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-23-2015, 12:29 PM   #3
crossy
crossy's Avatar
passenger side axle tube is where the stampings were on my 73-87's? sound right? haven't really looked at yet, but I don't remember this rear having a cover. it's pumpkin style in 61 right?
98 Vortec project.
94,3500,6.5L 4L80
Old 11-23-2015, 01:48 PM   #4
jtrichard
Jack up ONE side,with trans in NEUTRAL turn the wheel and count the turns on the drive shaft cut that number in HALF and you have the ratio .......IF the lifted wheel wont turn or turns very hard then you have a posi
jtrichard is offline   Reply With Quote
Old 11-23-2015, 01:52 PM   #5
61K10
61K10's Avatar
If you have a 61 tk and the rear is org. it has a pumpkin and a rear cover also. the axles have c-clips (y the cover) most were 3.90 gears with the 3 & 4 speed. post up a pic.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-24-2015, 02:31 AM   #6
Captainfab
60-66 Nut
Most '60-'62 1/2 tons came with the Eaton HO32/33 and 3.90 gears. The only other gear ratio available is 3.38. Yes they do have a drop out 3rd member but they also have a removable rear cover. I always recommend pulling the cover and having a look. Then bolt the cover back on with a new gasket and fill with some fresh gear oil. The differentials are one of the most neglected parts of a vehicle and yours could more than likely use an oil change.
Old 11-24-2015, 12:37 PM   #7
crossy
crossy's Avatar
NOPE,NOPE, the whole truck was obviously neglected equally.
actually I shall neglect it no longer , but I'm bettin dollars to donuts that no one stocks an Eaton HO32/33 rear gasket. at least it's easy to get to since there is no wood left on the bed floor. LMAO
98 Vortec project.
94,3500,6.5L 4L80
Old 11-24-2015, 01:08 PM   #8
61K10
61K10's Avatar
you can get the gaskets at any auto parts store here on the w/coast. don't know about NJ
1961 chevy K10
