Old 11-23-2015, 01:28 PM   #1
davepl
davepl's Avatar
Pic of factory camper wiring?
Does anyone know what the original (UY1 I think) camper wiring option consisted of?
I've read here that it just came with the truck, wasn't installed. Is it just the four-blade yellow/green/brown/white cable, or did it include the big 12g power cable too?
My truck trailer wiring was blown through the frame with a torch, very crude and ugly, so I retained none of it. I kind of need to start fresh, and want to do a full 7-pin, but keep it somewhat period-correct looking if I can.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-23-2015, 07:38 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Pic of factory camper wiring?
Here's what I had hanging off the firewall in my 70 GMC with the UY1. It ran down the inside of the frame to the back bumper. Here is a grainy wire code I found from this site.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-23-2015, 08:19 PM   #3
davepl
davepl's Avatar
I have that cable, and I don't have the truck at home so - why does it run under the hood? The signals and all of that would be picked up under the dash, so why do the green/yellow/brown etc come through the firewall and then into the engine bay?
Old 11-23-2015, 09:24 PM   #4
FirstOwner69
FirstOwner69's Avatar
The factory harness included yellow, brown and green wires for the camper tail and brake lights, a wire for backup lights, a white 12 or 10 gauge ground and a red 12 gauge hot wire. The 12 gauge red ran from the junction block on the right fender, was clipped to the top of the core support, and strapped to the front light harness back to the front of the cab. From there the harness(wrapped with wiring harness "tape") ran parallel with the standard rear harness inside the frame, through a hole (mine is also ragged) to the outside of the frame, and to the rear of the cab where it was secured by a clamp (clamp correct, bolt not correct in the pic below) to the lower back of the cab. According to the assembly manual it was then bundled and placed in the front stake pocket. I don't recall where my bundled harness was secured. The original clamp was secured with a hex head sheet metal screw. No connector was provided. That was left to the owner to select the appropriate version just as it is with the camper harness option on today's trucks.
Here's a bunch of pictures.
Jim
FirstOwner69 is offline   Reply With Quote
Old 11-23-2015, 09:25 PM   #5
FirstOwner69
More...
Old 11-23-2015, 09:27 PM   #6
davepl
davepl's Avatar
Thanks for the photos! I believe mine lived/will live exclusively on the driver's side since I have dual batteries.
Old 11-23-2015, 09:37 PM   #7
FirstOwner69
Pete (DeadheadNM) may be able to help with that. I think some of the pics above were, if I remember correctly, taken for a thread he started. He also has dual batteries.
Jim
Old 11-23-2015, 09:43 PM   #8
davepl
davepl's Avatar
Just FWIW, I'd want a grommet on the red truck's through-frame hole if it were up to me. Must have been official GM procedure to burn the hole with a torch (mine was WAY uglier though).
Old 11-23-2015, 09:49 PM   #9
FirstOwner69
I hear you. But, that's the way GM did it.
Jim
Old 11-23-2015, 10:26 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jim
Hi Jim!
I can post pics of my aux batt/camper harness set up if that helps.
Best, Pete
Old 11-23-2015, 10:54 PM   #11
jocko
jocko's Avatar
some camper wiring info for ya I found on the custom camper thread a while back and saved - think it was an SS Tim post.
Old 11-23-2015, 11:57 PM   #12
Andy4639
Old member
Andy4639's Avatar
Question Re: Pic of factory camper wiring?
Because all the trucks I've ever seen the wires all come out in the engine bay at some point and then under the truck to go to the rear end of the truck.
Where do you think they should come out at? Just wondering
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
