Old 11-23-2015, 05:24 PM   #1
lutjanid
Need help identifying 1972 k20 rearend.
The front axle is a Dana 44 and the numbers were easy to find. Not having any luck with the rear. I believe it to be the factory axle, but can't find any markings. Thanks for the help.
lutjanid is offline   Reply With Quote
Old 11-23-2015, 05:28 PM   #2
racerop
racerop's Avatar
Re: Need help identifying 1972 k20 rearend.
That's An Eaton
racerop is offline   Reply With Quote
Old 11-23-2015, 05:40 PM   #3
dozerbill72
dozerbill72's Avatar
On the drivers side of the pinion on the front if there is a bolt with a jam nut. the bolt would be pointing towards the drivers tire. It is a HO72 if it does not have that bolt and nut it's a HO52.
dozerbill72 is offline   Reply With Quote
Old 11-23-2015, 05:49 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
All HO72s (1-ton trucks) have the load bolt.... some HO52s (3/4-ton trucks) have it, and some do not.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-23-2015, 05:53 PM   #5
dozerbill72
Stocker, how do you tell them apart if it is a 52 with a preload bolt?
Old 11-23-2015, 07:55 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, the hard parts are supposed to be mostly the same. Only difference I am aware of is the brakes, which are bigger on HO72s. And possibly some bearings, but a search is needed to find that info.
- Mike -
RIP El Jay
Old 11-23-2015, 08:26 PM   #7
They are the same rear with different brakes and wheel bearings. I'm sure it's the HO52 Corporate rear since that's what would have come in your K/20. Sure,maybe someone changed it. But they are the same rear anyway. The only HO72 it could be would be from a single wheel C/30. Very few cab & chassis SRW C/30s were sold, mostly stepsides and Longhorns
Old 11-23-2015, 08:31 PM   #8
lutjanid
It is original to the truck, so that would make it the HO52. I would like to change out the diffs from 4.10 to 3.73, but it doesn't look that easy with the HO52. Dana 44 up front.
Old 11-24-2015, 12:23 AM   #9
swamp rat
swamp rat's Avatar
Not always true from everything i have read on this forum.. EDIT: Never mind i see it was already talked about..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-24-2015, 12:27 AM   #10
swamp rat
swamp rat's Avatar
I would really like to see some pic's of the HO-72 brakes, My K20 has the larger finned drums so i origionally thought it was an HO-72.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
