71 c10 long 307
Can i lose bellhousing tranny mounts and run just rear mount? Three on da tree.
Re: 71 c10 long 307
Yes..Are you removing the bellhousing xmember?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: 71 c10 long 307
Does that trans have bosses for a rear mount? Not all do. IF it does have the capability to bolt a mount on the back then I would say yes. But the question that comes to mind is why are you trying to reinvent the wheel here that setup has worked properly for several decades. Not try to bust you out i'm sure you have your reason I just don't see it. Jim
Re: 71 c10 long 307
Did not realize that nothing was missing ordered x member for nothing tnks for info guys!
Re: 71 c10 long 307
New to the game. Im sure ill have more stupid questions keep em running!
Re: 71 c10 long 307
My doors dont lock by key if i lock doors and close doors they unlock upon closing. If door is shut and i try to lock by key thumb lock moves down but not enough to lock doors. Any suggestions? Appreciated in advance!
Re: 71 c10 long 307
Nice truck joe. Im running the same no power nothing!
Re: 71 c10 long 307
Thanks, try pushing in on the door while turning the key. that helps sometimes. does the key lock it when the door is open ?
#9 | |
Its a Truck Thing......
Re: 71 c10 long 307
You should be able to lock them by either, with the key or pushing down the knob inside. Sounds like you have some internal issues that need to be checked. Also check your door alignment as the catch and latch may need adjusted to get the door to lock. Try pushing up on the door and using the key. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Re: 71 c10 long 307
Thanks I'll try that
Re: 71 c10 long 307
Could you give a few pointers on how to adjust doors\latches dont know where to start . They are not bad had to push in very little to lock . Tnks!
