Old 09-16-2003, 06:31 PM   #1
mhorning
mhorning's Avatar
Question for 86 k10 owners
I'm thinking about replacing the stock quadrajet on my 86. I know this carb is specific to this year. It has some sort of electronic thing built in to it. I'm wondering if anyone here has made a conversion and what did you use?
mhorning is offline   Reply With Quote
Old 09-16-2003, 08:12 PM   #2
Prerunner1982
Prerunner1982's Avatar
maybe i just dont know about qjets, but what electronic thing are you talking about? there is electronic choke if thats what you are talking about, but thats not specific for your year. more info would be great appreciated.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-16-2003, 08:55 PM   #3
mhorning
mhorning's Avatar
I believe it is called a mixture control solenoid. Its on top of the carb. Here's a pic
Old 09-16-2003, 08:57 PM   #4
mhorning
mhorning's Avatar
Try to attach this pic again
Old 09-16-2003, 09:54 PM   #5
apstguy
LED King
apstguy's Avatar
It was a 85-86 thing. I got the friggin thing too. If you live in CA, your truck came with one.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 09-17-2003, 09:43 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Hey, that's my carb in your pic! I'm practically famous...
I'm not sure what you are asking, but I think that Edelbrock makes an emissions legal replacement carb that gets rid of that thing. It is the 1904.
http://www.edelbrock.com/automotive/carb_qjet.html
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-17-2003, 12:16 PM   #7
CRRoy71
I also just bought the 1904. I will be putting it on the 383 that is in progress.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 09-18-2003, 09:41 AM   #8
BigRed
I've got that on my '86 'burb and was wondering just last night what it was. My truck was bought her locally so I don't think it's limited to Cali.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 09-18-2003, 06:35 PM   #9
apstguy
LED King
apstguy's Avatar
There is one problem. The statment is not really true about the 50 state legal. All the replacement carbs say "NOT FOR USE ON COMPUTER CONTROLED VEHICLE" meaning if you have one of those electronic carbs, you can't use it as a direct replacement. That also means if you have a CA truck, they are illegal.
Calif has more emissions stuff on them. I knew in CA you definitly had it, but I didn't know if it was federal too. If it was federal, I think it was an 86 only thing.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 09-18-2003, 11:57 PM   #10
crackajacka
Stylin
crackajacka's Avatar
ive got the same carb on my truck and i live in oklahoma
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 09-19-2003, 09:46 AM   #11
mhorning
mhorning's Avatar
Slonaker,
Yeah it is your carb. I used the pic from last time you helped with the wiring. Hope you didn't mind. It was still on my computer. The carb still runs rough, so I'm thinking about buying a new one.Thanks for the info
Old 09-19-2003, 09:48 AM   #12
mhorning
mhorning's Avatar
One other question. The quadrjet has a solenoid on the side of it the kicks up the idle when the AC is on. I noticed that the edelbrock doesn't. Think it should still work with AC trucks?
Old 09-19-2003, 10:01 AM   #13
Slonaker
Slonaker's Avatar
I'm not sure, but I think you can bolt your old one on in place of it.
No I don't mind you using the pic. I was just surprised to see it again.
Slonaker
Stock '01 Silverado
Old 09-19-2003, 01:07 PM   #14
BigRed
Mine is not connected right now on my stock Quadrajet. However, I have runon probably due to that it's missing. I checked with the Chevy dealership today and they want $90 for that part (Idle Stop Solenoid). However, you can get it at any other parts store for about $25 - $30.
Edelbrock also sells an aftermarket version of the idle stop solenoid. But it's pricey too!
By the way, whats the model number on these carbs? Just curious.
Scott Shelbourne
Old 09-19-2003, 02:14 PM   #15
mhorning
mhorning's Avatar
scott the model number is 17085226. Hey do you guys know if our truck has ESC control. I thought I heard that this carb worked with the distributor to maintain fuel air mixture. If so, I'm wondering if the computer that controls the system is screwing up my idle.
Oh and one more question, should this truck have an O2 sensor? I know I don't have one.
Old 09-19-2003, 04:52 PM   #16
Slonaker
Slonaker's Avatar
Our trucks have the ESC. You can find out if yours has been removed by looking t the distributor. It it has a flat plug about 1.5 inched wide hanging off the side, you still have the ESC in place. As far as I know, the carb is not computer controlled. Again, AFAIK, the ESC just retards the timing if the knock sensor (on the passenger side of the block, just above the oil pan) detects pinging.
Swervin has instructions for bypassing it on his site, www.73-87.com
BTW, I don't have an O2 sensor. I don't think it is supposed to have one, either.
Slonaker
Stock '01 Silverado
