Old 11-24-2015, 06:09 AM   #1
93FatBottom
Trying to track down a hydroboost brake pedal
I've been to all my local yards, I've been on craigslist almost daily. Does anyone know where I can buy a reproduction hydroboost pedal? For a 1987 V20. My vacuum booster is out so I want to do the swap now that I have an excuse to do so. I've been searching parts catalogs online for hours but can't find a part number either. Can anyone point me in the right direction? It would be MUCH appreciated! Thanks!
93FatBottom is offline   Reply With Quote
Old 11-24-2015, 09:15 AM   #2
CrewCab59
CrewCab59's Avatar
Re: Trying to track down a hydroboost brake pedal
I dont think that part will ever be made again , to many just setting around in yards.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 11-24-2015, 10:09 AM   #3
nonstop
Some pedals were drilled for both - mine was and I added a stud in the hydroboost hole. Might be worth a re check.
nonstop is offline   Reply With Quote
Old 11-24-2015, 11:31 AM   #4
MAXMAN
Junior Member
MAXMAN's Avatar
I'm pretty sure I have a complete pedal bucket assembly for a hydroboost. Probably have hyrdroboost unit and master if you are interested. Let me know, as I would not be able to get to them until Wednesday night or Thursday.
MAXMAN is offline   Reply With Quote
Old 11-24-2015, 01:53 PM   #5
manimal
manimal's Avatar
Auto or manual?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-24-2015, 02:20 PM   #6
MAXMAN
Junior Member
MAXMAN's Avatar
auto
Old 11-24-2015, 02:33 PM   #7
manimal
manimal's Avatar
Sorry, that was meant for the OP...
-Lance
Old 11-24-2015, 09:29 PM   #8
69heavychevy
69heavychevy's Avatar
Not to hi-jack the thread, but I was wondering if the pedal and mounting bracket are hydroboost specific or is just the pedal assembly itself?
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 11-26-2015, 06:53 PM   #9
chevak20
I am planning also to do a hydro boost swap later on.I got one some year ago from a diesel v2500 sub. Here are some pictures and numbers
chevak20 is offline   Reply With Quote
Old 11-27-2015, 01:07 AM   #10
chengny
chengny's Avatar
Depending on the type of transmission (automatic/manual), the bracket assembly used with hydroboost (JB8) brakes is the same as used with non-hydroboost systems (JB1, JB3, JB5, JB6, JB7).
The part number for all pedal brackets (hydro or non-hydro) used with a M/T is 15628778. Pedal bracket part number for all A/T applications is 15628779.
The above is true for 1985-1991 MY's and C/K/R/V models - but does not apply to trucks equipped with diesel engines.
chengny is offline   Reply With Quote
Old 11-27-2015, 03:57 AM   #11
chevak20
The diesel 4x4 Suburban 3/4 up to -91 have JD7 brake system. The pedal on my pictures matching JD7.
Do you mean that gas trucks paddles have both holes for the vacuum/ hydro boost rod?
Old 11-27-2015, 10:11 PM   #12
69heavychevy
Thank you for clearing that up.
