Old 11-24-2015, 10:12 AM   #1
chrismoore701
chrismoore701's Avatar
Speedo cable
My speedometer is bouncing, after research I decided to buy a new cable. I stuck it on a drill and tested it and it seems to work. The question is, is it possible to lube the old cable? Or is it a lost cause? I tried to spray lithium WD40 into the cable and didn’t seem to work What if I pulled cable out and greased it?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 11-24-2015, 10:54 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Speedo cable
You can leave it connected to the trans and disconnect from the cluster and pull it back through the firewall but otherwise leave the cable housing in place. Then pull the inner cable and check it for frayed spots/lube it up/run it back in. I think they're all of $10 at autozone if you need a new one.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
