Old 11-24-2015, 12:22 PM   #1
jfalesi
Junior Member
SBC heads - where's the oil fill port?
Can someone post a pic of the location of the oil ports on SBC heads? I need to add oil but my valve covers are off (the fill cap is on the valve cover).
jfalesi is offline   Reply With Quote
Old 11-24-2015, 12:43 PM   #2
mmiddle
mmiddle's Avatar
Re: SBC heads - where's the oil fill port?
Don't have a pic BUT... The drain ports are in the upper corners. These drain into the valley.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-24-2015, 01:11 PM   #3
jfalesi
Junior Member
By upper corners, do you mean on the inboard side (the side nearest the intake manifold) near the valves? I know they're at the front and back of the heads, but I can't tell if the holes are on the inboard or outboard sides. There's oil pooled in both places.
Old 11-24-2015, 01:22 PM   #4
GRX
GRX's Avatar
You can just slowly pour oil onto the head and it will find it's way to the return holes - marked red in the image. Or you can drop a funnel into one of the large holes between the push rods. The shape will depend on which era head you have.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 11-24-2015, 01:40 PM   #5
jfalesi
Junior Member
Cool, thanks :-) That's exactly what I was looking for. Here's a numbered pic of the head holes. Can anyone correct me and/or fill in the blanks?
This forum rocks!
1) ?
2) Oil port
3) pushrod port
4) ?
5) pushrod port
6) ?
7) ?
Thanks,
-Jamie
Old 11-24-2015, 01:52 PM   #6
GRX
GRX's Avatar
1) head bolt
2) Oil port
3) pushrod port
4) open hole to lifter valley
5) pushrod port
6) head bolt
7) valve cover bolt hole. That image is of Vortec head that uses center bolts. Older style mounts are on the gasket rail as seen on the bottom of the 2nd image I posted above.
Hope that helps.
Old 11-24-2015, 01:57 PM   #7
jfalesi
Junior Member
1) head bolt
2) Oil port
3) pushrod port
5) pushrod port
6) head bolt
Hope that helps.
Thanks GRX!
