11-24-2015, 10:11 PM | #1 |
locks
I can't lock my doors in the closed position with key . please help! If i lock by hand then close door it unlocks upon closing doors.
11-24-2015, 10:38 PM | #2 |
Re: locks
Why can't you use the key?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-24-2015, 11:05 PM | #3 |
The Older Generation
Re: locks
They are designed not to lock by pushing the button down and closing the door so no problem there. Are you sure your ignition lock cylinder hasn't been changed and the key will not fit the doors? LockDoc
11-25-2015, 12:40 AM | #4 |
Old member
Re: locks
With door open will the key turn in the lock cylinder? If so close the door with it unlocked and while turning the key push in on the door. If it locks then you will need to adjust the strikers and possibly the door itself to get them to lock!
