![]() Join Date: Sep 2015
1979 C10 temp. gauge and alternator questions.
Temp gauge in the dash works good but where does it get its reading from?
Coming out of the intake, theres a wire that runs to a temp gauge that is zip tied onto one of the master cylinder lines?? No idea why its there, but its accurate also. Fixing to replace the alternator with a 94 amp for a 85 camaro, on the back of the alternator theres the 8 gauge wire and another 16 or 18 gauge wire that goes directly to the battery, should the small jumper wire be there? This is a nice truck but a D.A. owned it before me. |
Moderator
![]() Join Date: Oct 2008
Re: 1979 C10 temp. gauge and alternator questions.
Temp gauge sender is in the LH cylinder head.
Got a picture of the extra wire on that 12SI?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
That yellow wire goes to the battery it's connected to the back of the alternator. |
Moderator
That's the BAT stud. The output wire is supposed to be there.
Someone did some bubba wiring there. Is this yellow wire on your truck or the donor F-Body? On the CK trucks the output wire is a red 12ga wire that runs from the BAT stud to a fusible link on the firewall J block for charging the battery. The red wire on the plug terminal 2 goes to a fusible link on the starter. This is the sense wire that monitors the system voltage to regulate the output voltage. The brown wire to terminal 1 is a resistance wire around 45-55ohms that goes to the ignition switch on gauge option trucks. On the low option trucks this same wire would have no resistance to the GEN lamp on the dash. This is the ignition/indicator lamp wire. This terminal is a ground till the regulator starts calling for charge then it becomes full system voltage to turn off the warning lamp.
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-25-2015 at 10:30 AM. |
This is my sons truck, don't understand f body donor?
Moderator
You were talking about using a 94A Delco 12SI from a 1985 Camaro... I assumed it was still in the donor chassis.
F-Body = Firebird-Camaro. If you're buying a rebuilt alternator a CS130 will give you more amperage. If you're having charge problems fixing the original alternator circuit is a good place to start.
Thanks for the help.
I was going to go to NAPA and get a rebuilt alternator, no problems just getting ready to put a new motor in and was going to go with dual fans on the new radiator. I'm sure this was the cheapest alt the po could use. I'll get the one you recommend. So just leave the yellow wire where it is? |
Moderator
This is a snippet of the 1979 wiring diagrams with the alternator and starter hookups.
GM called the alternator a generator in the earlier wiring diagrams. Don't know why. The big fat wire at the starter is the 2AWG battery + lead. Decoding the wire labels. The wire label consists of 4 parts. Wire gauge, color, circuit#, and wire type. In 1979 the wiring diagrams used mm rather than AWG for gauge. There's a conversion table on page 1 of the 1979 wiring diagrams. The charge wire on the alternator BAT terminal is labeled "3 RED-2C (SXL)"... "12AWG RED Circuit 2C SXL wire". The fusible link at the Junction Block is labeled "1 RED 2F THERMO HW" which means "16AWG RED Circuit 2F Fusible link wire". Wiring diagrams etc are in the RTFM links in my signature...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-25-2015 at 11:46 AM. |
#9 | |
Moderator
I'm not sure what the PO (previous owners) were trying to fix... At a guess the red 12ga charge wire is damaged. If the red wire from the alternator BAT terminal to the J block on the firewall is damaged I'd fix the red wire and ditch the PO "repair".
Damn, thanks again for all the great info.
Im book marking this page for reference, ill use the diagram and figure out what they did. |
