God is good!
PCV Routing to Open Element Air Cleaner Base?
I'm installing a Holley 650 DP and Edelbrock Performer 2101 manifold on my '73 K20 with a 350. Due to the limited vacuum ports on the carb, I'm figuring to route the PCV valve to the fitting on the base of my open element air cleaner. I've read mixed reviews in the 'nets, but is there really a good reason NOT to do this?
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Re: PCV Routing to Open Element Air Cleaner Base?
One valve cover needs fresh air - you can plumb that on the clean side of the air filter if you want.
One valve cover needs the PCV receiving manifold vacuum - this won't work at the air filter, it needs to be the manifold.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
What about a carb spacer?
God is good!
I have a breather on the passenger side valve cover and want to have the PCV plumbed to a port underneath the air cleaner on the base. There's a port under there for this. Are you saying there won't be proper ventilation like that?
God is good!
Already have a 1/2 spacer/baseplate, didn't want to add another.
#6 | |
Dino burner
Another problem with the way you want to do it is that there is not much vacuum inside the air cleaner housing, so you won't effectively evacuate blowby gases out of the crankcase. The preferred method is to have the blowby gases re-enter the engine below the carburetor so they do not negatively affect the way the carburetor does its job. Perhaps a photo will help: ![]() In the photo I linked to, filtred air from the inside of the air cleaner travels through the fitting in the air cleaner base you want to use, through the breather hose and into the crankcase to replace the gases that are pulled out via the PCV valve. |
#7 | |
Dino burner
![]() The PCV hose can be hooked up to the spacer port because you do not have one at the base of the carburetor. |
Why not use the port on the rear of the intake?
![]() Join Date: Jul 2000
It was sorta implied above, but the PCV valve needs full manifold vacuum. Vacuum won't be pulled on the crankcase if you connect the PCV valve to the air cleaner.
The hole on the other valve cover is where you draw in fresh air (either through the air cleaner or a filtered breather). So, the air flow path is breather -> crankcase -> PCV valve -> manifold vacuum source. The entire idea is to suck out corrosive gasses from the crankcase, draw them in the combustion chambers, and burn them.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#10 | |
God is good!
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 Last edited by TheWhiteElephant; 11-29-2015 at 02:21 AM. |
God is good!
I hadn't given that much thought. I may have to use a "T" from the rear port on the intake. I will be running the transmission vacuum and PCV on there if I do.
The carb has one large port at its baseplate on the rear--this is the one I'll use for the brake booster. The QJet use to have a large port on the rear and one in the front of its baseplate. ![]()
Agreed with all above about not routing the PCV line to the top of the carb.
Common practice is to T the intake manifold port for the transmission and brake booster, and to run the PCV to the dedicated port on the back of the Holley 650 double pumper. Keep the oily air away from both the brake booster and transmission lines.
Rich Weyand 1978 K10 RCSB DD. |
