Old 11-25-2015, 05:34 PM   #1
Phjeo
engine horsepower estimate
Hey Guys, i have been a member on here for a while but haven't posted much. wondering if someone could help me with estimating the HP of my new motor.
Here are the details i know of
350 chevy block bored .30 over
stock crank
extreme energy XE274H-10 comp cam
stock rods
roller rockers
flat top pistons
Edelbrock performer 6073 heads that have been decked
Edelbrock performer air gap intake
Holley 750 carb that i need to jet back a bit
1972 Chevy C10 SWB 2wd
1987 Chevy 4x4 SWB
1997 GMC SWB 2wd
2007 GMC Z71 extended cab 4x4
Phjeo is offline   Reply With Quote
Old 11-25-2015, 09:04 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: engine horsepower estimate
The Performer heads will easily support 1HP per cube. Sounds like a well built motor, if cylinder seal is good I'm sure you have made or exceeded that.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 11-25-2015, 09:44 PM   #3
cableguy0
If compression is at 10-1ish I will say 375hp and 415ft lbs of torque. Lower compression and the numbers drop. As Marv stated its a good combo and you didn't over cam your setup. It should be a good runner. Regardless of the actual dyno numbers the seat of the pants dyno should be happy. That combo is going to like a lot of timing though. I wouldn't be surprised if it wants 36-38 total at 3k rpm and likely 16-18 at idle.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-28-2015, 12:36 PM   #4
Phjeo
thanks for the reply guys. looking forward to getting this motor in and running. it's replacing a tired out 283 so i am sure the "seat pant dyno" will be much different than the old motor.
1987 Chevy 4x4 SWB
1997 GMC SWB 2wd
350 engine build, 355 build, hp estimate
