![]() Join Date: Dec 2014
Running without Vss
Any of you guys running without your Vss hooked up? I'm running a turbo 350 and I have an auto meter electric speedometer with the sender that goes into the cable side of the Trans. So I can hook my speedo up that way. Am I gonna see driving issues without the Vss hooked up?
Re: Running without Vss
have done it a lot. no issues.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
If you're running a manual transmission it usually isnt a problem because you push in the clutch when you come to a stop, but with an automatic if you come to a quick stop without a VSS the PCM doesn't know that youre stopping and can take a while to compensate so sometimes they will stall.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
| Bookmarks |
