Source for the "smaller" radiator - 6 cylinder maybe?
I remember hearing there is a smaller radiator that can fit in the lower saddle mounts on the front crossmember. This radiator should be narrower I believe to fit between frame rails. Does anyone have any data on which year and engine truck this was offered? My searches are only showing 1 radiator I believe.
Re: Source for the "smaller" radiator - 6 cylinder maybe?
Should be about 23" wide total possibly
![]() Join Date: Aug 2008
I have a couple of used radiators that I can measure for you. Came out of mid-60's with 6 cyl.
Thanks that would be helpful. If you look down on your core support panel there are 2 unused holes which I hear are for a small radiator. This would be a good option for my build but not sure if its possible to acquire.
60-66 Nut
![]() ![]() Join Date: Mar 2007
What you want is a radiator for a '63-'66 with a 230/250 I6 without the heavy duty cooling option. You will also need the side shroud pieces and the top mount.
Thanks Captain. Thats what I've been looking for! There is an intercooler where the factory radiator sat (approximately) but the area for the smaller radiator is wide open and the smaller radiator is more than enough cooling.
EDIT: any idea if theres a company popping out new ones of this? Rockauto is showing radiators that are about 25-26" wide only for the 63 C10 230cid. |
If you have to buy a radiator, Radiator Express has really good prices. About half the price of LMC. Aluminum 2 and 3 row.
I have one in my truck the same way you described it! I have a 250. What your are looking for it a Radiator for a 6 cylinder made by Champion Radiators. I don't Remeber the serial number. I think it's E6067
Here you go!
http://www.championradiators.com/Che...6cyl-1960-1966 This is what I have and it sits on the lower cross member |
Thanks!!!
This is what I got- let me know if what you are looking for.
more
#13 |
Thanks for the pics - those dimensions are going to help a lot when I get out to the truck tomorrow.
What about the top bracket. Can that be sourced new or any used sources? Shroud I will make but that top bracket to the core support I still need. |
#14 |
I have a top bracket too. no pic though
#15 |
BigSix; If you were close to Indianapolis there is a radiator for a 64 I-6 sitting next to my garage waiting to walk away.
DPowers: IS the u shape for sale? Mine is rusted on the right side about 4 inches. |
#16 |
I appreciate it. Looks like I am grabbing DPowers shroud and top mount and then ordering a new radiator. This should have me rolling and looking factor. You won't even be able to tell theres an intercooler back there.
#17 |
Just found out today, that, I to, need a new radiator. After some investigation, I found that the one, currently in my truck, is a CHRYSLER! Yeah, it's got to go (it does have a few leaks). Ok, so I've got several issues.
I will add this disclaimer: I'm new to the forum, and I'm new to this truck. It's a 65 stepper 1/2 ton. I6 250. So any and all suggestions are greatly appreciated! 1. The front radiator core supports are totally rusted out. (How hard is this to replace?) 2. Wrong radiator (Chrysler) 3. Missing all shrouds. (Is this an item I can buy?) Thanks! JT Last edited by jturner18; 11-27-2015 at 01:07 AM. Reason: forgot something |
#18 | |
#19 |
#20 |
![]() Join Date: Dec 2011
we make bolt in radiators for the 63-66, but ours were sized to the V8 specs:
http://67-72chevytrucks.com/vboard/s...d.php?t=591690 ![]() |
