Old 09-16-2003, 08:51 PM   #1
dion
72 Cheyenne
dion's Avatar
okay, how was I able to drive around for 2 days without my rad cap?
I was working on the truck on Sunday checking fluids and such and today when I pulled into my driveway I saw my radiator cap laying there, never even came close to overheating, city and freeway driving. I was amazed but somebody out there probably has a story of when they drove around for a year without one
and no, I'm not an idiot!
I don't understand why it didn't get hot, especially the way I drive.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 09-16-2003, 10:17 PM   #2
67'ShortMonster
Your coolant will still flow without a rad cap. It's just that the cooling system will not cool as well without the pressure. That's why when you blow a small hole in your rad... Undo the rad cap... Sometimes you get a lot farther without the pressure there.
67'ShortMonster is offline   Reply With Quote
Old 09-16-2003, 11:09 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The pressure raises the boiling point. If your engine was not heating it up to X degrees, (what does 50/50 boil at...is it 275?) then the pressure was not neded.
Straight water boils at 212 if not mistaken, and I know I start to panic if the guage gets over the 200 degree tick myself.
Old 09-16-2003, 11:24 PM   #4
dion
72 Cheyenne
dion's Avatar
thanks guys, learn something new everyday. I was always told you needed the pressure.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 09-16-2003, 11:25 PM   #5
dinnut
dinnut's Avatar
reallly? thatts aweeesooommm!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-16-2003, 11:30 PM   #6
Longhorn Man
You only need the pressure if the heat is high enough...or if you are going through Denver.
I had a rad that was literally falling apart and had to make a trip from Tx to Ky. I just pulled the little finger up on the cap, (I always get the finger type) and drove it 1000 miles there, 1200 miles while in Ky for a month, and then 1000 miles home. No problems at all.
Old 09-17-2003, 01:34 AM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Chevy trucks didn't use a pressurized cap until 1952, when they started using a 4 lb. cap.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
