How do you install the Parking Brake mech?
So right when I parked in the garage and pulled the parking brake lever pulled all the way up and the cables under the truck fell -,- how do I put back together the parking brake?
Re: How do you install the Parking Brake mech?
The gear is stuck, and I can't pull the trigger and the lever won't pull :/
![]() Join Date: Jan 2011
You need to go through the cables and see what may be froze up or worn. Pull the pin out the cable at the top on the handle and you should be able to easily pull the cable back with the arm under the truck in the picture. The arm inside should work. Take a pic of the cable parts under the truck so we can see if anything is worn out. Looks like a 66 setup and I will look to see if I have pictures of the complete system.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
So the pin broke in this dowel that holds down into the bracket that pupils the brakes
Fixed it!
Good to see you were able to fix it. If the cotter pin fell out it would all come apart.
Jimmy
