Old 11-26-2015, 01:20 PM   #1
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Ball Joints 1969 vs. 1972
Ordered new ball joints for my rig.
I'm using a 1969 frame and control arms and swapping spindles, disc brakes, and all the steering components from a 1972.
Ball joints were shot on both frames, so I ordered new ones for a 1972 as I'm using 1972 spindles. Moog has 2 different part numbers for ball joints from 1969 and 1972. I'm assuming it's because of the taper of the ball joint shaft since the spindles are different.
So my question is... will the 1972 lower ball joints press into the 1969 lower control arms? I do have the 1972 control arms as well... but the 1969's are all cleaned up and coated, where the 1972's are just a greasy mess.
I'm also assuming that the 1972 upper ball joints will just bolt in like any replacement into the 1969 upper control arms.
Thanks! Happy Thanksgiving!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-26-2015, 08:07 PM   #2
midniteblues
midniteblues's Avatar
Re: Ball Joints 1969 vs. 1972
The 72 ball joints will fit the earlier control arms. Pressed or bolted.
As long as your use ing the 71-72 ball joints with the same year spindles your good to go.
The one thing I'm not sure on is the steering stops on the lower control arms. But my kids truck has pretty much the same setup as yours with no problems.
Glad too see your workin on it.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
