88-91 front end conversion harnesses available!
Just thought I'd mention I have several versions of this harness available now. I built none for a member here and they can be built either as stock replacement or with H4 plugs, sealed beam, etc. And, I can incorporate the remote washer pump for those using the 87-up drivers side fender washer jug with the built-in washer pump.
I have the schematics for 81-86 up trucks and are complete from the firewall plug out-includes high temp looming, rosebud clips and all the proper breakout locations and core support/frame grounds. I upgrade all the wiring, everything is soldered and the kits can have relay integrations for power and/or delay off capability. Here's a few pics so you have an idea-PM or post here with any specific questions about options. PM or email for price quotes-this thread is just meant to inform everyone that these are available in several configurations for those updating their front ends and would like the best plug n play harness conversion for it. |
At the body shop.
Re: 88-91 front end conversion harnesses available!
What about the other way? I have a 91 crew and want to swap to a 73-74 clip.
" That didnt make it any newer " " Dont antique the equipment " |
Well, I do have 73-80 front lighting harnesses also-I can build it that way if you need it. The 88-91 trucks have a different style bulkhead connector but I stock those also so yes, if you need it setup for a 73-74 front end I can supply you with that. PM if you want so we can nail down what options you want incorporated with it or if you want a simple stock type replacement I can do that too. You may be the first person I've built that style of harness for...lol but I have schematics which I've drawn up so its no big deal.
At the body shop.
I thought the bulkhead connection was different. And it would be a stock style harness.
I need to collect up the sheetmetal for the swap 1st. And I might go with the 86 style clip too. Which I would think the harness is different too. Thanks.
Correct-those bulkhead connectors too are different. It doesn't matter which direction you opt for, I can build a harness accordingly for you whenever you're ready.
