11-26-2015, 11:49 PM | #1 |
Engine questions???
I have a 1962 GMC steoside pick- up. The engine is stuck and was just wanting some opinions on what engine that would be good to put in it. I've heard 350 but everyone usually does it. Thanks in advance.
11-27-2015, 01:43 AM | #2 |
Re: Engine questions???
I think before you take advice from anyone you should decide what you want to accomplish. Is it going to be a daily driver? Will you tow with it? Is performance or fuel economy more important to you? How much fabrication are you willing to do? Do you want it mostly stock, or are you going for modern convenience?
Once you decide what you want to accomplish, it narrows down the field considerably. |
11-27-2015, 08:11 AM | #3 |
I would like to hear more about the old engine.... Stuck????? what is in it now, how long has it been "stuck" what exactly is the issue , do you mean locked up??? have you tried to rotate it by hand, you might have a good rebuild-able core already that could save you some money depending on what you are looking for.
if you are going to the trouble of pulling it out, you might as well put it apart and find out what is going on and if it can be rebuilt..???
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-27-2015, 10:15 AM | #4 |
If it has the 305 V6 rebuilding will be difficult unfortunately. If it has an Inline 6 then rebuilding is cheap and easy.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-30-2015, 01:08 AM | #5 | |
11-30-2015, 11:30 AM | #6 |
Again...what engine is in there?
12-08-2015, 02:14 AM | #7 |
12-08-2015, 03:50 AM | #8 |
kinda tough to beat a crate 350 and thats why everybody does it. Putting it in your truck would be pretty simple with some V8 frame mounts. You`d need the pulleys and such and some headers but really simple. The $1500 crate engine would be perfect for a daily driver and make a lot more power than your current set up.
Anthony |
12-08-2015, 07:54 AM | #9 | |
12-08-2015, 09:42 AM | #10 |
Registered Truck Offender
If some is good, and more is better, then as MUCH as you can stuff in a 4" bore block is just right. Well maybe not 'as much' You can stroke a 4" bore to 396 with a 3.875 stroke, but it's not as cost effective as a 383 which has became a shelf stock, pick up the phone and one will be at your door in a couple of days.
STROKE = TORQUE,, that's why the lowly little 305 v8 does so well in heavy vehicles with it's tiny bore. Add stroke to the 4" bore and you get near BigBlock cubic inches in a small lightweight package. How can you go wrong
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-08-2015, 10:59 AM | #11 |
If you can afford it do it. It's not something that you will regret doing a later on.
Anthony |
12-08-2015, 11:28 AM | #12 |
You'll probably be better off going with a different engine. Rebuilding the V6 is getting harder and harder because so many people are dumping them for a SBC. A 305 V6 is better than a 350 in the fact it will outlast it and will out lug it any day of the week(My V6 is pushing 200,000). The 6 mpg is bogus. Properly setup with a 5 speed tranny and taller rear gearing these engines MPG increase. Stock mine got pretty good mileage as I would cruise around with it. But like said...cheapest way would be a crate 350 and you'll have something for good general and reliable use. You could pull that V6 apart and see what has caused it to lock up and if its nothing major then it could be fixed. I'd go too this site here for some info on that engine: www.6066gmcguy.com/EngineData.html
12-08-2015, 11:45 AM | #13 | |||
"I ain't nobody, dork."
So you don't want to do a 350 but will consider a 383? Kinda the same thing just a tad different. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-08-2015, 11:59 AM | #14 |
laying low
If you dont want to go with the 350 then go with a 305 v8. They are plentiful and cheap. They are economical too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-12-2015, 03:00 AM | #15 |
I'm working on mounting a Vortec 4200 in my 54.
I've been driving a Trailblazer for over 200,000 mile and love these motors. It's not a straight up swap, but not too difficult so far. It's definately different. There's lots of info here. http://www.vortec4200.com/ Here it is between the frame rails. http://s1074.photobucket.com/user/wh...64309260847403 I have motor mounts made now, and have slightly trimmed the front crossmember. I need to remove the center bellhousing mount and get the trans mount in. The Trailblazers/Envoys/Bravadas/ and Rainiers are getting plentiful in the junk-yard now. You should be able to get a complete package realitively reasonable. |
12-12-2015, 03:54 AM | #16 |
Fabricate till you "puke"
Just say LS.....I sold everything gen I, my old 69 runs a 5.3. Stiil lookin to up the ride. But with 6 gears, on the row, do I need to explain the ride? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
