Old 11-27-2015, 01:56 AM   #1
Bonzai
Head light issue
Low beam and high beam on passenger side operate normally
Low beam on driver side dim and high beam doesnt work also the high beam indicator on dash always remains on
Could really use some help on where to begin
Thank you in advance
Bonzai is offline   Reply With Quote
Old 11-27-2015, 03:16 AM   #2
87Skier
87Skier's Avatar
Re: Head light issue
Some weird issues there. I would think that it is either the headlight itself, the ground on the core support, or something to do with the dimmer switch/headlight switch.
Try disconnecting the left headlight to see if that fixes the bright indicator remaining on.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 11-27-2015, 07:16 AM   #3
cdowns
cdowns's Avatar
start by cleaning up all the contacts on the headlight bulb to bright shiny metal to metal contact including the ground wires
Old 11-27-2015, 12:19 PM   #4
Skinny Kid
Mine had a similar issue when I got it. Right headlight low beam wouldn't work and indicator was on. Changed bulbs, same thing. It was dirty contacts at the right side connector and bad ground. I ceaned all contacts and installed headlight relays. Now my low beams are brighter than my high beams used to be.
1971 Chevy Custom Camper/20, Hugger Orange with White Top
31,000 original miles (when purchased), 402, TH400, PS, PB, AC
As of May 2017 it now has a turbo LS in it! (Still looks stock though)
Skinny Kid is offline   Reply With Quote
Old 11-27-2015, 12:22 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Bad contacts or the dimmer switch on the floor is shot.
A faulty dimmer switch can cause all kind of wonky headlight issues.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-27-2015, 03:20 PM   #6
davepl
davepl's Avatar
OK, super long shot here.
If in the low beam lamp the low beam filament melts and makes contact with the high beam filament, the low beam could light the dash indicator. Unplug from foot switch for a moment to check.
Failing all of that, it'll be a simple manner of tracing power on the brown and light green wires. Brown is low beam. Light green is high beam. The indicator on the dash is power by, you guessed it, the light green wire.
Unhook the headlights, then start tracing the power on the two wires and fine when/where it doesn't match with what it should be doing.
I've never had a dimmer switch fail ever in any car, but someone will likely describe the symptoms of that, could also be a cause but not side to side.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-27-2015, 07:29 PM   #7
Grumpy old man
Grumpy old man's Avatar
Always check your ground contacts for any type of lighting problem first .
Grumpy old man is offline   Reply With Quote
