gas tank strap pads? where sells them
Only place I am finding them are like corvette places sure they'll work just curious if there was somewhere that sold more correct ones for our trucks most I'm finding are sticky backed my originals don't appear to have been sticky backed.
thanks |
Hollister Road Co.
Re: gas tank strap pads? where sells them
try tanks inc.
I went down to the local semi tire repair place and they gave me a blown intertube. I cut it up and used some 3m adhesive. Worked good enough
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
I did the same as chrismoore701. A blown tire tube worked well, and 3m super 77 held mine in place while u put the straps on.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
I had some tar paper left over when my house was roofed . I doubled it with some spray adhesive . Worked out pretty good .
78K & 79C Jimmys
Yup, (mountain) bike tubes work good too, I've slid it over them,
installed, cut out the strip left over for the other side
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Moderator
![]() Join Date: Oct 2008
30lb asphalt impregnated roofing felt is pretty much the same material as the original GM squeak strips.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
God is good!
I made some from some material from Home Despot/Lowe's. Here is a link to what they look like. Post #71
http://67-72chevytrucks.com/vboard/s...=430367&page=3
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Thanks guys I'll check into those options.
question, did our originals come with one side sticky though? mine I don't think did but could have I guess but seems just STUCK due to age and weight of the tank. just curious if I do decide to order from one of the truck sites. |
Robert Olson Transport
![]() Join Date: Oct 2002
I used felt paper comes out good
If the ones you have are use able. What I did was lay them out and give them a thin spray of undercoating. Wait a few minutes and flip over and do the other side. once dry enough to handle install. It worked really well it sticks to the tank and seals out the moister and look factory. Using a tube will work but it looks off and the moister gets in between and will rust far quicker.
I just got them from LMC. Item 13:
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=51
Rich Weyand 1978 K10 RCSB DD. |
#13 |
![]() Join Date: Jun 2009
DO NOT buy LMC! It is literally roofing tar paper that they over charge for! It even has the lines for roofing! On top of them overcharging it is very lightweight tar paper! I threw mine away once they arrived from LMC
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#14 |
Thanks, i ordered some from corvette central through amazon, should work.
#15 |
Collector of Projects
I also went the home depo route with a recycled rubber matt. Cut to fit the straps and for a Blazer tank, the front and rear edge. It was just under $10 and I can do 12 more installs...
