rear end questions...
Looking to swap out the gears on my truck.
Currently has the original 12 bolt non-posi rear end. (suspect it's 4.11's now but haven't pulled the cover to check.) Anyway, since I'm running a granny sm465 I'm figuring that I can go with some pretty tall gearing 3.07 or 3.08 (what's the story with those two? why are there both out there). I know I need a new series 3 carrier as well but what exactly 'am I looking for with regards to years, models etc. Also, I'm running a 292 at the moment but will eventually be putting in a 327 anyone have thoughts on the gearing choice? I know that there are 3.42's but I'm doing more freeway than I thought and I'd really like to be able to cruise comfortably at 70 with either motor (28" tires on the truck). Don
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
Re: rear end questions...
Keeps getting asked, here the chart again. I would say you have the typical 3.73 rear
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
thanks, appreciate the post but that's really not what I was asking.... easy enough to determine how to get the 70mph cruising RPM via a chart but that doesn't tell me what it's like to pull away from a stop on a hill or tow or many other real world situations. I'm hoping for some feedback from those who have a similar setup and whether they would change anything if they could... more importantly I'd like to know what parts I should be looking for (what parts interchange with my housing, any years that don't work, why a 3.07 and a 3.08, are all 12 bolts the same? etc). Thanks again.
#4 | |
#5 | |
Don't plan on doing any towing, just hauling a bike or two from time to time and some building materials. MPG, nothing I own gets anything good in that department. More like yards per gallon ![]()
I had a 81 c10 with 3.08s a 26.5" tire and 75 was 3000rpm. Your granny gear will help out with tall gears but before you spend all that money look for an overdive. Either motor is still reving high. Taller tire will do the same. I would keep the gears and slow down. Not like my truck now with all new stuff, I am sure you need to freshen up everything like ball joints, steering and brakes before hitting 75.
#7 | |
The good news is the truck is pretty tight overall as it's only just turned 80,000 miles. I've done the driveshaft, u-joints, brakes and shocks so far and will continue to freshen things up as needed. You mention overdrive, are speaking of something like a gear vendors or switching to T-5? I know the gear vendors are like $3k which is not in the budget. What should I expect to pay to have a new carrier and gear set installed? I know the used parts are pretty reasonable. Thanks for the input, much appreciated.
I think the story on the 3.07 vs 3.08 is that 3.07 is for pick ups and the 3.08 came in cars.
I bought a 66 with trashed differential and found one from a 64 with 3.73`s. Teaching my daughter how to drive she asks where is the next gear and I say that's it. She thought that was pretty funny. In the city or on the farm 3.73`s are good but way too slow on the highway. I found a 71 differential with 3.07`s and like it a lot more. It will do 65 MPH quite nicely. 3.73 with overdrive might be even better combining good low end with good top end. |
Any and all od. Look under big ford's for GV od alot of ford guys, my uncle included, had a big nasty 460 and dropped in a Gear Vendor. Long ago I waited 6 months for a t5 , now i saved up and dropped $2500 on New , But a good 200r4 or 400r can be had at less than 2000 with warranty . Remember every time you pass a Bug or Bus there top speed is 65 or less. I had the 9 class offroad car at 75 max desert racing.
Relax take the slow road, most people will give you props and then there are Prius a holes who will speed because they want to save the planet.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 11-27-2015 at 08:53 PM. |
Just noticed your in SF. Bullitt had 4 gears and traffic you want gears. Enjoy the ride!
60-66 Nut
![]() ![]() Join Date: Mar 2007
With the 3.07 gears you will have to start out in 1st gear instead of 2nd gear as is normal with a SM420.
All truck 12 bolt parts are interchangeable from '63-'82. But beware that the '63 and '64 12 bolts had 17 spline axles and spider gears. the '65-'82's have 30 spline axles and spiders.
I have a 75 blazer with a sm465 and 3.07 and 28" its great on flat ground (or down hill in a hurricane LOL) BUT hard to get it rolling and you have to down shift on the slightest hill and mine has a 350 ..... 3.07 is more for an auto trans .....i would stay around 3.42 for all around driving with a stick
#13 | |
#14 | |
#15 | |
#16 | |
#17 | |
FWIW, my father's truck has a 350 with 3.07 gears and my borrowed 3.11 Saginaw 4 spd (currently running 255/70r15's on the back). We both like the way that combo drives (at least in this area) and 75MPH is just a little over 2,700RPM. As I have pointed out many times in the past, what is "screaming/about to blow up/comfortable" is also very subjective. My truck has 4.10 gears with a 307/SM420 combo and 235/85r16's, so 2,700RPM is 60MPH for me. It doesn't bother me if I have to run 70MPH @ 3,150RPM to keep up with traffic when I need to. |
#18 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
People drive faster than they should.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#19 | |
![]() ![]() Join Date: Aug 2013
The 10 bolt rear-end had a 308 ratio and is not interchangeable among the two. Any gm truck 12 bolt internals will work, it is just the housings and axle lengths that changed between vans and trucks and 4wd vehicles. So if you find a donor rear-end with the ratio you want, you will have the gears and carrier to convert yours provided they haven't been damaged in their previous life. Add a bearing kit to complete the reassembly, and you will be in good shape. I did my 62 using a 65 housing and used some OEM 342 gears with an Eaton series 3 posi and I turn 2900rpm at 65MPH on the freeway with 28" tires. Good luck on the decisions Joe |
#20 | |
#21 |
Six in a row makes it go...
![]() Join Date: Mar 2009
I put 3.07 gears in my '66, but I also put in a Richmond 5-speed.
My brother had a '68 with a 327, SM465, and 3.73. The rpm drop between gears was pretty large, since the 465 is, in effect, a 3-speed. You may not like the rpm drop between gears with the 3.07… That said, we drove to Alaska with a 250, 3-on-the-tree, and 3.07.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#22 | |
#23 |
![]() Join Date: Aug 2015
had that exact setup in a 72 4x4 with a 350 sbc. the six has more torque but I live in the mountains about an hour north of tahoe and I found myself downshifting a lot on hills. after messing with these trucks for 30 odd years i believe the 373-411s were for three on the tree, granny gear 4 sp, 342 ratio is for 7oor4, and 307 were for turbo 350-400 three speed auto. hope this helps
#24 |
1956 Willeys Jeep
289 Ford 2 barrel, 4 speed, 4.56 and 35 in tires top speed 75. All around 55, enough for Mustang trashing in 1/4. Just saying our aerodynamics suck but some mpg can be had
