Old 11-27-2015, 03:38 PM   #1
Myoldtruck
Myoldtruck's Avatar
Towing airstream with my C10
Ok, so im getting ready for spring of 2016 with my new to me 70 c10. Any suggestions on rear suspension upgrades or what not to tow my 1969 airstream safari. The trailer is 23ft long, 420lb tongue weight, about 3900lbs dry weight, trailer has its own electric brakes. Im going to be using weight distribution bars on the hitch also. I will be going over my truck, new hoses, oil changes, grease front end ect.
[IMG][/IMG][IMG][/IMG]
Myoldtruck is offline   Reply With Quote
Old 11-27-2015, 04:11 PM   #2
doo142
doo142's Avatar
Re: Towing airstream with my C10
NICE set up!! I don't think you need anything special beyond a good hitch set up and brake controller. Best of luck!
doo142 is offline   Reply With Quote
Old 11-27-2015, 04:12 PM   #3
Eddie H.
Eddie H.'s Avatar
That's a nice looking rig. I especially like the fact that the truck and trailer are from the same era. Other than the normal checking belts, hoses, fluids, etc and making sure the cooling system is in good condition, you should be good to go.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 11-27-2015, 04:44 PM   #4
hamjet
hamjet's Avatar
Thats a sweet set up. some will tell you to up grade to power disc brakes on the front, but as you say, you will be using trailer brakes. It still would be a good idea though incase you loose power to the trailer brakes. thats alotta weight to stop in an emergency. You could add a sway bar to the front which will improve cornering and handling alot.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-27-2015, 04:54 PM   #5
72gmguy
72gmguy's Avatar
Maybe some overload springs.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 11-27-2015, 06:08 PM   #6
kwmech
Coil rear or leaf? either way I would look for an air bag overload
kwmech is online now   Reply With Quote
Old 11-27-2015, 06:55 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Here are pics of my '78 Argosy [20'] 'Minuet Six Meter' behind my '71 Jimmy.
I've sold the trailer since, but I miss it.
Pulled real easy.
I added a brake controller, and had a shop rebuild the trailer's electric brakes. Also they rigged some wires so the trailer batteries would recharge from the GMC's battery when on the run.
Old 11-27-2015, 07:12 PM   #8
davepl
davepl's Avatar
When travelling with an older vehicle like this, I would also always keep a fuel pump, alternator, and maybe water pump with me.
They're all reasonably high failure rate items, cheap, and nice to have on hand. Even if you have to go to a shop, having the part can save you a day's wait at least.
I have (but am not selling) an NOS air level kit for these trucks; even if you didn't find an NOS setup, basic air shocks might be useful for load levelling it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-27-2015, 07:28 PM   #9
1971KYC10
Based on the attached chart, there may be other variables to consider - e.g. rear end gearing.
1971KYC10 is offline   Reply With Quote
