Old 09-16-2003, 10:19 PM   #1
GMC 3
height of 1/2 ton rear cab mount bushing
switched my cab over from a 3/4 ton frame to 1/2 ton frame, but already had the new cab and radiator bushings for 3/4 ton. installed them and the rear of my cab sits too high. i checked with catalogs and it looks like the front cab bushings and radiator bushings are identical between the two. It looks like if I cut about an inch off of my rear cab bushing the truck will sit the way its supposed to. If someone could measure the height of a 1/2 ton rear cab bushing for me I would appreciate it.
GMC 3 is offline   Reply With Quote
Old 09-16-2003, 11:55 PM   #2
crazy longhorn
Fabricate till you "puke"
if you swap the rear frame brackets from athe 3/4 ton( that the cab mounts sit on) , you will be right on target on the height. The cab will have a little better ride also with the 3/4 ton rear mounts. The only bear is that you have to chisel off some rivets. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
