Old 11-27-2015, 05:45 PM   #1
primetime
primetime's Avatar
68 trans crossmember
What's the trick to installing this thing? I removed the stock one from my 72 to use on the 68 that surprisingly was missing it. I don't want to remove the cab and exhaust in order to install this. Didn't think I would have to either but.... At this point I might just spent money and buy the tubular type crossmember. It looks like it would be less stressful.
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 11-27-2015, 07:24 PM   #2
kwmech
Re: 68 trans crossmember
which transmission?
kwmech is online now   Reply With Quote
Old 11-27-2015, 08:17 PM   #3
primetime
primetime's Avatar
Oh it's the turbo 350
Old 11-27-2015, 10:53 PM   #4
kwmech
Is it all still 1 piece or have the rivets been cut making it a 3 piece?
Old 11-27-2015, 11:18 PM   #5
hugger6933
If the top parts are still there grind off the rivet heads knock them out then place the crossmember under the truck crossways then with the trans jacked up some turn the crossmember into the frame. the motion is like twisting it into placethen when the bottom is in place bolt the top part back up to the crossmember if you choose to a lot of guys leave that step out.
hugger6933 is offline   Reply With Quote
Old 11-28-2015, 11:19 AM   #6
primetime
primetime's Avatar
Thanks guys. I'm gonna try this later today
