Old 11-29-2015, 01:58 AM   #1
PS1947/5W/1/2T
1947 Chevrolet 3100
Hello,
New to this forum..
I recently bought a 1947 1/2 ton 5 window Chevrolet truck.
My question is if anyone knows if there is actual difference in overall measurements Length and high of the truck between 1947 1/2 ton and 1947 1/2 ton Thriftmaster ?? or - and what this ,,Thriftmaster'' means ?
Thank for all the help!
Pete
PS1947/5W/1/2T is offline   Reply With Quote
Old 11-29-2015, 07:09 AM   #2
msaintg
msaintg's Avatar
Re: 1947 Chevrolet 3100
do you have any pics? It is my understanding that those are one and the same thing. I have never seen a 5 window '47, not to say they don't exist, just I have not seen them. My '47 was the base model and it still said thriftmaster on the emblem.
mike
msaintg is offline   Reply With Quote
Old 11-29-2015, 07:53 AM   #3
1project2many
Thriftmaster is the marketing name for the engine. IIRC the 261 available in 2 ton trucks was sold as the Loadmaster.
1project2many is offline   Reply With Quote
Old 11-29-2015, 10:01 AM   #4
PS1947/5W/1/2T
mike
Thanks Mike for the answer..
Here are some picture.
Old 11-29-2015, 11:23 AM   #5
torchlight
torchlight's Avatar
You might have a non-47 cab on there - at the very least those are 52-54 doors because they have the vent windows and push button handles.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 11-29-2015, 11:38 AM   #6
74project
nice grab.. looks clean... is that already on a s10 frame..
74project is offline   Reply With Quote
Old 11-29-2015, 11:39 AM   #7
50 Chevy LS3
Is the gas tank in the cab, or, under the bed?
Steve.
1950 Chevy, 3100, built in Norwood Ohio, USA.
My build thread, http://talk.classicparts.com/showthread.php?t=19110
50 Chevy LS3 is offline   Reply With Quote
Old 11-29-2015, 11:44 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
You have a 1947 second series 5 window Chevrolet Thriftmaster. It should have a gas fill between the cab and bed on the right side. Thriftmaster was used much like Apache and Silverado are. Your Serial number should start wit EP if its a 47 half ton. The doors as stated are later.
dwcsr is offline   Reply With Quote
Old 11-29-2015, 11:50 AM   #9
PS1947/5W/1/2T
The gas tank is under the bed, gas filler nose in between cab and rear fender..exiting on side of the bed.
Old 11-29-2015, 11:53 AM   #10
PS1947/5W/1/2T
So it might be a 47 truck but with later doors, am I understanding it right?
If i buy regular 47 door windows and trim, would i be able to replace it so it looks like 47 door from the outside?
Old 11-29-2015, 11:58 AM   #11
PS1947/5W/1/2T
Thank you!
The Chassis number starts with EP....Before that there is a #3 and then it continues with -K Do you know what that means?
Old 11-29-2015, 12:06 PM   #12
PS1947/5W/1/2T
Smile Re: 1947 Chevrolet 3100
It should not be! I hope I have not took a look at it that close yet.
Old 11-29-2015, 01:37 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by PS1947/5W/1/2T View Post
Thank you!
3 - 3100 1/2 ton
EP - 1947
K - St Louis MO plant
Old 11-29-2015, 01:41 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
The window mechanism and tracks are different, the glass is different the door latching and handle are different. It would be easier to get 47 to 50 doors. Not 51's as they are only for 51.
Old 11-29-2015, 02:48 PM   #15
PS1947/5W/1/2T
Big Help, Thank you for all the information!
Also I attached picture of the rear end and suspension.
What do u think, Does it looks stock to you?
Pete
Old 11-29-2015, 05:43 PM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
Yes its stock.
Old 12-22-2015, 06:20 PM   #17
PS1947/5W/1/2T
Hello, Do you know if there was a difference in gauges with red needles or gauges with white needles?
Pete
Old 12-22-2015, 08:41 PM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
Pete
Not in the operation but there were different color needles in different year trucks, I don't know what year has what color but I believe 47 should have a white needle. Some of the knobs were also different color between years. Gauge mounting lugs can also be different on a 47. I do know first had that 50 gauges don't bolt in to a 47 dash without changing the back cover
54 and 55.1 were a different gauge in appearance and mounting.
Old 12-27-2015, 11:43 AM   #19
Gippetto
Does it have a single shackle assembly pivot supporting the rear of the cab? If so it is a '47 cab. That uses two rubber bumper pads out towards the cab corners. That was replaced a few years later with rear shackles at the cab corners.
Gippetto is offline   Reply With Quote
Old 12-27-2015, 11:52 AM   #20
MARTINSR
MARTINSR's Avatar
God please noooooooooo
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 12-27-2015, 12:26 PM   #21
Henry50
Henry50's Avatar
Brian
Wow, I thought I was the only person on this forum that that can't stand the s10 frame swaps.
Henry50 is offline   Reply With Quote
Old 12-27-2015, 12:54 PM   #22
PS1947/5W/1/2T
I am going to check that out soon.. Not sure what to look for and where exactly but this single shackle assembly I should be able to find it behind the seat ??
47' was the only year that had the single shackle?
Pete
Old 12-27-2015, 12:56 PM   #23
PS1947/5W/1/2T
You are Definitely Not the Only Person : I don't like frame swaps ... Just for the fact I like original cars.
Old 12-27-2015, 01:15 PM   #24
MARTINSR
MARTINSR's Avatar
Yes its stock.
Brian
1948 Chevy pickup
Old 12-27-2015, 01:20 PM   #25
MARTINSR
MARTINSR's Avatar
In my opinion, first off, we are all different. I can't say this enough, we are all different and we have different needs. I am talking personally here, ME personally, I loath the idea. I don't see a vintage truck anymore when it's done. In my opinion it's not a 1950 Chevy pickup with an S-10 Frame under it, it's a 1990 S-10 with a customized body to look like a 1950 Chevy pickup.
I just hate to see it because sooooooo often it's done by people who don't know that they could be driving the stock truck or a modified stock frame just fine, they don't need anything more, it's not a big deal to drive the stock truck with the drum brakes and all every day, it's soooooooooo over thought. "Can't drive with drum brakes on the modern highway" I want to SCREAM.....as I drive my stone stock 1959 Rambler every single day.
Sorry original poster, back to the cool new truck you bought.
Brian
1948 Chevy pickup
