![]() Join Date: Feb 2004
So tell me about the 1964 4X4 1/2 ton long beds
I found one (GMC) and was going to buy it but it's not compleatly original, it has a Chevy 350 in it that seems to be a common replacement engine. It is a K series and original 4X4. Anyone know about how many were made? Good trucks? I know quite a bit about the 67-87's but not much about these.
Thanks |
Post Whore
![]() Join Date: Mar 2013
Re: So tell me about the 1964 4X4 1/2 ton long beds
I don't know about a 1/2 ton LWB 4X4....I know they had 3/4 ton models. I would wonder if its on the original frame or if it was converted over.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Oct 2013
Agree with "TJs Chevy" that the frame is a good place to start evaluating the trucks originality. Their are production numbers available on certain model from GM heritage. Production numbers for chevrolet 64' K10 long bed fleetside are around 1200 to 1300, if I remember correctly.
Just posted some frame pictures on build "64' K10 Project Long Bed" , that may help some. A few thing to look at are certain parts riveted, frame holes that 4x4 have, spring length, frame crossmember that supports radiator, transfer case crossmember mounting to frame rails ( is it a Rockwell t221) . Their should be lots more information here to help. Les Last edited by aotte1; 11-29-2015 at 01:07 PM. |
they were made in 1964/ late 63. what else did you want to know about them
ron |
![]() Join Date: Jan 2013
I remember reading somewhere that there were under 2000 Chevy 1/2 ton 4x4s built in 1964, but I can't find the article now. I have one, so if you need pictures of anything, I can get them.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
Active Member
![]() Join Date: Jul 2013
The original thread started as a GMC question but it has morphed into some 1964 Chevrolet K10 information so I am throwing this out there, FYI.
According the to the GM Heritage center, they don't have the GMC numbers but they do indicate Chevrolet built 1,324 1964 K10 LWB Fleetside trucks. |
The morph to chevrolet was me, thought some of the Chevrolet information might relate to GMC. Hope some of it helped a little.
Les |
Post Whore
Check this site:
www.6066gmcguy.com/index.php
![]() ![]() Join Date: Apr 2012
Heres some Chevy info. GMC im going to say should be close but Im leaning on less made. Ive only seen total production per year on Jolleys GMC site , no breakdown by model.
1965 K10 1/2 ton swb chassis cab 48 1965 K10 1/2 ton swb stepside 1,127 1965 K10 1/2 ton swb fleetside 633 1965 K10 1/2 ton swb Panel 103 1965 K10 1/2 ton swb Carryall (barn doors) 444 1965 K10 1/2 ton swb Carryall (gate) 433 1965 K10 1/2 ton lwb chassis cab 52 1965 K10 1/2 ton lwb stepside 513 1965 K10 1/2 ton lwb fleetside 1,459 1965 K20 3/4 ton lwb chassis cab 308 1965 K20 3/4 ton lwb stepside 889 1965 K20 3/4 ton lwb stake 1,364 1966 K10 1/2 ton swb chassis cab 40 1966 K10 1/2 ton swb stepside 1,123 1966 K10 1/2 ton swb fleetside 678 1966 K10 1/2 ton swb Panel 170 1966 K10 1/2 ton swb Carryall (barn doors) 530 1966 K10 1/2 ton swb Carryall (gate) 418 1966 K10 1/2 ton lwb chassis cab 30 1966 K10 1/2 ton lwb stepside 457 1966 K10 1/2 ton lwb fleetside 1,976 1966 K20 3/4 ton lwb chassis cab 431 1966 K20 3/4 ton lwb stepside 924 1966 K20 3/4 ton lwb stake 1,796
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
![]() My first 66 ![]() ![]() ![]() |
The numbers are crazy low for 4Bys.
#13 |
![]() Join Date: May 2010
Nice looking truck, Congrats!
It only has original paint once |
#14 |
