Old 11-29-2015, 02:12 PM   #1
Clavo106
And another Rear lsd or locker thread.
ok have questions and hopefully someone can school me. since the only thing iv done on diff is regular maintenance repairs and such.... nothing on after market. I have a 327 with a th400 rear is a 12 bolt 3.73 open dif. ok im in the market and looking..
My needs list..
would like to drive it daily but i would also like to do the regular burn out now and then !
would also like the swap to be easy since I have not done one before.
Clavo106 is offline   Reply With Quote
Old 11-29-2015, 04:46 PM   #2
swamp rat
swamp rat's Avatar
Re: And another Rear lsd or locker thread.
In the market for.....????????
Different internal gears?
Positraction?
Different whole rear end?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-29-2015, 05:11 PM   #3
cleszkie
cleszkie's Avatar
You can do burnouts with an open differential just fine (with one tire). I would steer clear of any sort of positive locker or spool, as the annoyance from the chattering/clunking, during engagement and disengagement will more than outweight the enjoyment of laying down two stripes instead of one. Not to mention the crazy tire wear you will get. I think a positraction differential is what you want. However, these do not just drop in like some of the "lunch box" lockers out there. Your best bet is to have someone install it for you, or try to find a rear end with a posi already in it and swap it in.
cleszkie is offline   Reply With Quote
Old 11-29-2015, 06:03 PM   #4
Clavo106
Lots of good points there guys!... bbbbbbuuuutt IMO one wheel burnouts are not cool! as it would be smoking two tires. idk looking at the information from other popular builds ..maby the Eaton Posi or truetrac.. cleszkie make the good point on the chatter engagement witch would consider me a bit.. idk.. hopefully there a in between livin' the dream.
Old 11-29-2015, 06:09 PM   #5
leftybass209
leftybass209's Avatar
I wouldn't consider gear swap easy or cheap. The cheapest and easiest way to do this is to find a used posi rear someone is selling. To swap gears involves tools and techniques you probably haven't used before (this is an assumption based on the question), and it's pretty easy to get a chewed up gearset and/or carrier if you do it wrong.
the more expensive, and slightly more difficult way to do this, is to pull the rear end, completely disassemble it (to save on cost) and take in down to a rear end shop to have them rebuild it.
leftybass209 is offline   Reply With Quote
Old 11-29-2015, 06:50 PM   #6
grillzy
lock right locker
grillzy is offline   Reply With Quote
Old 11-29-2015, 06:50 PM   #7
Z10
Z10's Avatar
PowerTrax. I have one in my 72 GMC and my 69 Camaro. I've got around 7000 miles with one on the truck, it's quite and gets the job done.
http://www.powertrax.com/index.php/p...ertrax-no-slip
And the video: https://www.youtube.com/watch?v=8k-LmnS3ED0
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 11-29-2015, 07:28 PM   #8
grillzy
Yes this is what I meant.
Old 11-29-2015, 08:38 PM   #9
Clavo106
i like everyone input..i do tend to read a lot of reviews befor a buy... but still on this two because of popular vote. Eaton Posi or truetrac..mmm..?.. as for me doing the work very comfortable me doing the work..I understand y people choose not to do certain jobs mosty money time are the same and having to do it twice or paying the same for having it done ur self is no fun. the only reward is experience.. but I can handle this.. there is plenty info on the web and here..
Old 11-29-2015, 09:44 PM   #10
BCOWANWHEELS
eaton posi, its not harsh on tires and will get the job done. also its rebuildable and not hard on axle shafts. just put one in mine last week.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-29-2015, 10:40 PM   #11
T.N. Stroker
T.N. Stroker's Avatar
The Lock Right locker's are a very good option for what your looking for. Easy install and very durable and streetable as well. Prices are very reasonable.
T.N. Stroker is offline   Reply With Quote
Old 11-29-2015, 11:32 PM   #12
BCOWANWHEELS
Dissadvantage to any locker is when your on the gas there locked up period
Old 11-30-2015, 12:05 AM   #13
Z10
Z10's Avatar
Just for clarity, the PowerTrax acts like a locker when you drive in a straight line. When you are making a turn, it releases unlike a locker.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 11-30-2015, 12:21 AM   #14
Clavo106
well guess the only concern I had with the powertrax is the life span.7000miles? i do belive it will do the job..the info u prov is helpfull.....
Old 11-30-2015, 09:46 AM   #15
Z10
Z10's Avatar
What I meant is the truck now has 7000 miles on it with no issues from the PowerTrax. Everything is working great.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 11-30-2015, 02:34 PM   #16
americanmusc1e
americanmusc1e's Avatar
I had one of these in my old rear end. It was smooth as glass with thick 80w140 oil and an auto trans. As long as you didn't throttle it in the corners you couldn't tell it was there.
THEN, I replaced the auto with a SM465. It squeaked the tires around every corner. My guess is that the Sm465 has such a heavy gearset that it kept a steady load on the driveshaft (even with the clutch pushed in) and caused the locker to get confused and lock up.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
