11-29-2015, 05:05 PM | #1 |
Edelbrock 800AVS Carb
I hate to get rid of this but I don't for see needing it and it's been just sitting on the shelf. It's Edelbrock's 800AVS model number 1813 square bore carb. I bought it new from Summit for $419.99 a few years ago as well the jet kit.
http://www.summitracing.com/parts/edl-1813/overview/ http://www.summitracing.com/parts/edl-1841/overview/ I ran it a while and found the 650AVS worked better for me. I put the carb back to stock, replaced all the gaskets including airhorn, primary and pump shot squirter gaskets, as well as replaced the idle adjustment springs. The floats are properly adjusted, the needle and seats are in good shape and the filters are clean. There are no leaks and it is squeaky clean. I'll include the jet kit as well. $250obo plus the ride. Thanks for looking, Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 11-29-2015 at 05:20 PM. |
12-03-2015, 09:53 AM | #2 |
Re: Edelbrock 800AVS Carb
I snap more pics if someone would like.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
12-06-2015, 05:35 PM | #3 |
come on you hot rodders! one of ya needs this.
01-11-2016, 11:23 AM | #4 |
Bump
01-11-2016, 07:17 PM | #5 |
This would look good on my edelbrock rpm intake... Can I get a shipping quote to 41018
01-12-2016, 11:53 AM | #6 |
Through USPS, I can get the shipping down a bit if I break the carb and jet kit up into two packages and not use the original Edelbrock carb box. The carb will fit in a large flat rate box with packing for $17.90 and the jet kit separate for $5.95 for a total shipping to you at: $23.85
So total of: $273.85-5.95= $267.90 Steve PS: Scratch that, the USPS large flat rate is 12x12x5.5"s. Looks like I can get the jet kit in that box as well and still get good packing around the carb. $267.90
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 01-12-2016 at 12:18 PM. Reason: PS: |
01-12-2016, 05:56 PM | #7 |
Sold to 72c105speed!
Thank you Fred, I'll PM you the tracking number tonight.
