Old 11-30-2015, 12:55 AM   #1
slotard
Window doesn't roll up easily
'73 C20, manual windows. In order to not feel like I'll break the handle I have to pull up on the window when rolling it up. Is there something specific that's likely the problem? I'd like to be able to close it more easily.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 11-30-2015, 01:02 AM   #2
Matt Man
Matt Man's Avatar
Re: Window doesn't roll up easily
clean and grease the track do simple stuff first. Mine was completely seized on my truck on the drivers side.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-30-2015, 11:01 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
WD40 it
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-30-2015, 11:31 AM   #4
Liberty
Liberty's Avatar
Originally Posted by old Rusty C10 View Post
WD40 it
Or use my favorite, PB Blaster!
Liberty is offline   Reply With Quote
Old 11-30-2015, 12:55 PM   #5
TKCR
TKCR's Avatar
It could be several things.
1) your regulator itself is seized up, in which the wd40 or pb blaster will help.
2) it could be the runchannel rubber is dry rotted and pieces of it have gotten wedged up in the channel causing the window not to go up easily.
3) it could be the window is no longer in the rubber, it could be running up between the rubber runchannel and the sash. I have seen this happen.
The best thing to do, is to take the liner off, so you can look around on the inside while rolling the window up & down to see what is causing the friction.
Old 11-30-2015, 02:29 PM   #6
MikeB
MikeB's Avatar
Mine was the same when I got the truck. I simply removed the door panel and lubed everything that rolls or slides. I probably need a new regulator, but the window rolls up much easier than before.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-30-2015, 03:57 PM   #7
slotard
Regulator on manual windows? What does that do? Anyone have a diagram?
1973 C20, 350/350
Old 11-30-2015, 04:04 PM   #8
Matt Man
Matt Man's Avatar
Here is a picture of a manual regulator.
http://www.ebay.com/itm/CHEVY-73-87-...NWTf4G&vxp=mtr
Old 11-30-2015, 04:36 PM   #9
slotard
Thanks. I don't quite see why it's called a regulator...
My window certainly isn't as solid as it should be, so I suspect the channel has problems. Is the LMC stuff any good?
1973 C20, 350/350
Old 11-30-2015, 05:07 PM   #10
TKCR
TKCR's Avatar
Its just called that. It's either a power regulator or manual regulator.
The rubber, if you can't find OEM, then Precision is good.
Old 12-01-2015, 05:21 PM   #11
MikeB
MikeB's Avatar
It regulates the window position.
Mike
Old 12-01-2015, 05:51 PM   #12
cadillac_al
I think you will find the problem easily once you get the door panel off. Something must have broke or came loose. I have one that has been that way for a few years, just never got around to fixing it yet.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-20-2016, 01:31 PM   #13
slotard
Anyone have a link to a walkthrough? I've never even pulled a door panel before.
1973 C20, 350/350
Old 02-21-2016, 02:56 AM   #14
TKCR
TKCR's Avatar
http://youtu.be/mczSAD3egbw
1aauto has all kinds of how to videos on our trucks.
