11-30-2015, 01:22 AM | #1 |
bad gauge or bad thermostat p
So my trucks been doing something weird lately, my aftermarket temp gauge is jumping back and fourth from 195 to 245 every few minutes so bad gauge or bad thermostat? Its not boiling over any suggestions thanx in advance guys
11-30-2015, 11:31 AM | #2 |
I know the pieces fit
Re: bad gauge or bad thermostat p
Drive it a day or two with the thermostat out. That's the easiest way I know to tell quick. If it quits jumping around the thermostat was sticking.
11-30-2015, 11:35 AM | #3 |
Thanx bruiser I'll try that out today
12-02-2015, 12:55 AM | #4 |
So far so good mornings suck trying to warm it up. I think I'm do for a new motor either way
12-02-2015, 03:49 PM | #6 |
Last time I change my plugs they were looking pretty corroded
12-02-2015, 04:06 PM | #7 |
what happens when you ground out the wire from the sending unit ?
12-02-2015, 04:14 PM | #8 |
Its a sunpro mechanical gauge.im guessing its a bad thermostat since the temp isn't bouncing around
12-02-2015, 04:17 PM | #9 |
summit had the sunpro mini gauges on sale for 8 dollars last month. glad you got it figured out
12-02-2015, 06:33 PM | #10 |
No I didn't LOL just got home from hitting a few stores gauge was sitting at 135 for about 2 miles then jumped up to 200 which isn't bad but seems strange that for it to not stay steady since I don't have thermostat in it
12-02-2015, 07:46 PM | #11 |
That's odd. The bad thing about that is it swung proportionately, so you can't really rule out it's not accurate. I don't know though.
12-02-2015, 08:07 PM | #12 |
Maybe a bad temperature switch
12-04-2015, 12:27 PM | #13 |
yep I'm shooting for bad gauge. this morning took my son to school it shot up to 250 for a minute then shot back down to 180. still not running a thermostat. going to order a new gauge from summit and put my thermostat back in.
12-04-2015, 12:27 PM | #14 |
sorry for the upside down pix nor sure why it did that
12-04-2015, 01:18 PM | #15 |
semi hijack.
anyone experience a low reading on the gauge even after a new sensor? I was running a 180 and upped it to a 195. I still read 180 on the gauge and ~175-180 when data logging. I believe this is still affecting my idle and sometimes closed loop. I am on my second sensor, same reading. Thanks Chris |
12-04-2015, 01:26 PM | #16 | |
12-15-2015, 11:41 AM | #17 |
I bought another sensor, (3rd one) and it now reads ~195. Passed smog easily.
