Old 11-30-2015, 02:46 AM   #1
gasguzziler
Stuck door any help appreciated
So I just got a project 69 c10 that I'm trying to get back on the road and I've hit one major hurdle, I can't get the passenger door open. I've used every kind of penetrating oil I have on it and have gotten the lock working and the handle working good but can't get the door to budge even a little. I've gone thorough all the posts I could find and they just suggest oil and brute force. Well I even sat inside and kicked it while someone else pulled and held the button with no luck. Then I got the idea that maybe it was an alignment thing so I pulled off the fender and took all the bolts off of the hinges and still couldn't get it to budge. I'm about to have to go to the tedious task of cutting off the backing plate to release the door catch but that's really my worst case scenario and would rather not have to do that. Does anyone have any ideas. Thanks in advance
gasguzziler is offline   Reply With Quote
Old 11-30-2015, 03:31 AM   #2
Gully
Re: Suck door any help appreciated
I went through the same thing on my 69 except it was on the drivers door. Try removing the door panel on the inside and check operation of all those components. If everything seems fine there brute force us the way to go. I used a chunk of 2x4 and a long pry at to get mine open.
Gully is offline   Reply With Quote
Old 11-30-2015, 10:26 AM   #3
joeydurango
joeydurango's Avatar
Re: Stuck door any help appreciated
I bet the pushbutton (outside) and lever (inside) aren't even activating the latch. As Gully said, take that door panel off the inside and make sure the parts are all connecting as designed - if the latch is worn, things can just slip past each other instead of engaging. If they are worn, you can often disengage the latch with a long flatblade screwdriver or something similar.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
