Old 11-30-2015, 11:16 AM   #1
Old Crow
Old Crow's Avatar
VIN tag rivets
OK, so the '54 truck is almost done. I've got the new VIN tag, got it stamped with the serial number, got the new, correct rivets from Classic Parts.
Now, all I need to figure out is how to crimp the rivets. Did a search of the forum. Lots of discussion on the tag itself, but not much on the rivets beyond where to get them. Anyone got an easy way to crimp these?
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 11-30-2015, 11:56 AM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: VIN tag rivets
Not much more complicated than this slide the rivet into the hole slide the tool head over the "shaft" of the rivet and close the handle until the shaft pulls off or it doesnt move and trim with some side cutters
http://www.walmart.com/ip/20753575?w...591832&veh=sem
Valarius_Starchaser is offline   Reply With Quote
Old 11-30-2015, 12:27 PM   #3
Old Crow
Old Crow's Avatar
Re: VIN tag rivets
I've got the original style rivets, not pop rivets:
http://www.classicparts.com/1947-59-.../#.Vlx48XkQXIU
Old Crow
Old 11-30-2015, 12:42 PM   #4
1project2many
Re: VIN tag rivets
You need a rivet punch / die set. You might be able to use tools designed for soft copper rivets in leather. Google leather rivet punch and you should find plenty of examples.
1project2many is offline   Reply With Quote
Old 11-30-2015, 12:48 PM   #5
Valarius_Starchaser
Re: VIN tag rivets
Doh sorry! My mouth was moving faster than my brain on that one...
Heres some literature on it I like the idea in option 2
http://web.archive.org/web/200102140...ivinstall.html
Old 11-30-2015, 01:58 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: VIN tag rivets
Put it in the hole and use a punch to flatten the inner dome. That spreads the rivet out at the bottom. Make sure your tight against the plate and door frame.
dwcsr is offline   Reply With Quote
Old 11-30-2015, 03:11 PM   #7
918733
Re: VIN tag rivets
Yep a punch works real good
918733 is offline   Reply With Quote
Old 11-30-2015, 06:22 PM   #8
Old Crow
Old Crow's Avatar
Re: VIN tag rivets
I kinda thought they worked that way just looking at them, but at $8 for a pair, I thought I'd ask before I had to buy more. I just bought a brand new set of roll pin punches, I bet one of them will fit real nice. Thanks.
Old Crow
Old 11-30-2015, 07:13 PM   #9
_Ogre
_Ogre's Avatar
Re: VIN tag rivets
the link you posted is the id tag rivet
vin tags are spot welded on (task force)
my 58 vin tag came off when sanding the jam
i used 3/32'' pop rivet to put it back on
id tag pic with those rivets
vin tag spot welds
shop air compressor timer
Old 11-30-2015, 07:26 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: VIN tag rivets
Your top pic is the serial number tag (vin) on 54 they we not welded on. Either rivets or screws, the lower pic is 55.2 and up
Old 12-01-2015, 03:23 PM   #11
curmudgeon
Re: VIN tag rivets
Mr. DWCSR is correct, on my '54 I bought the exact same style rivets and used a center punch to flatten them. I did take the extra step of gluing my original scratched, faded VIN plate to my freshly painted door jamb to ensure that it doesn't fall off, I wanted the Classic Parts rivets to have it look authentic, but not necessarily have to hold the plate on very well.
curmudgeon is offline   Reply With Quote
Old 12-01-2015, 03:54 PM   #12
Old Crow
Old Crow's Avatar
Re: VIN tag rivets
It's a '54(I believe I mentioned that in the OP) and the tag looked just like the top pic. The pin punch worked perfect and we're good to go. Now all I gotta do is get the dual carbs synced up and the gentleman can take his truck home.
Old Crow
Old 01-05-2016, 09:56 PM   #13
Boom
Re: VIN tag rivets
What did you use for stamping the vin?
I need to do this but all of the vins I have seen the letters are different sizes than the numbers. I have a 48.
Boom is offline   Reply With Quote
Old 01-05-2016, 10:53 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: VIN tag rivets
Harbor freight has a stamp set that has all the numbers and letters the same size. 1/4" for $15
Old 01-05-2016, 10:57 PM   #15
Boom
Re: VIN tag rivets
I have that set. I didn't know if there was some special set that is needed. I assume 1/4 inch is the factory original size.
Old 01-06-2016, 12:36 AM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: VIN tag rivets
Its close. I've done a few and it looks legit
Old 01-10-2016, 09:08 AM   #17
Old Crow
Old Crow's Avatar
Re: VIN tag rivets
Yeah, the Harbor Freight set is what I used. Looks good to me.
Old Crow
Old 01-11-2016, 02:14 PM   #18
butchp
Re: VIN tag rivets
Find an airplane mech. he will have rivet tools.
butchp is offline   Reply With Quote
