11-30-2015, 12:14 PM | #1 |
Windshield seal
I bought a 69 C/10 that is a bit of a mutt and has a door, door panels, rear axels and differential from a 72. To be honest at this point even though the vin # on the plate inside the drivers door on the cab matches the 1969 stamped number on the frame under the hood I'm not convinced that the cab is from the 69. Is there a way to physically tell cabs apart from the 69-70 years to the 71-72 years The reason I'm asking is I need to change out the windshield seal and the parts apparently are different according to Steele rubbers web site. One part is for 67-70 and the other part for 71-72. I need to figure out which seal I need to buy. I'm suspicious because the seal on it now fits terribly on the inside of the cab but looks ok on the outside.
Posted via Mobile Device |
11-30-2015, 12:19 PM | #2 |
Re: Windshield seal
The 67/68 wont have provisions for the foot pedal style ebrake. Late 71-72 will have a vent in the door jamb. There are several other differences but nothing major. Only difference I know for the seal is the base seal with no trim and the upper level seal with trim. There are plenty of threads on the forum pointing out cab differences.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-30-2015, 12:32 PM | #3 | |
11-30-2015, 12:46 PM | #4 |
Re: Windshield seal
I looked it up on LMC's website. It looks like the difference is on the trim. Probably wider vs. narrow. Just make sure you get the matching trim with the seal.
11-30-2015, 01:06 PM | #5 | |
11-30-2015, 02:45 PM | #6 |
Re: Windshield seal
71 cab will have raised triangle shaped pad where inside rear view mirror attaches to, 72 had this mirror mounted on windshield itself so no holes in between visors. If no raised pad or mirror isnt screwed between visors (and no holes) the cab should be 69-70 if it has a foot operated ebrake.
"You can take the man out of PA, but you can't take PA out of the man" |
11-30-2015, 03:27 PM | #7 | |
