Old 11-30-2015, 12:20 PM   #1
The1960APE
The1960APE's Avatar
Oil Pan for a 1961 Apache LS Swap ?
Hi guys,
I need to order my oil pan today, I have searched and searched the swap thread but cannot come up with any swaps for a 1961 where a direct fit oil pan part number was stated, I was looking at the Holley 302, CTS-V and F body but I cannot find any information on which one will fit the best. The truck is lowered and running the stock front end set up besides drop spindles. Any help would be greatly appreciated as I need to order the pan today!
The1960APE is offline   Reply With Quote
Old 11-30-2015, 03:17 PM   #2
The1960APE
The1960APE's Avatar
Re: Oil Pan for a 1961 Apache LS Swap ?
Maybe a better question is will the LH8 pan work?
Old 12-01-2015, 02:01 AM   #3
68c10airstream
68c10airstream's Avatar
I used the "F" body pan as it's the thinnest in the front area and the shortest in the deep area. Just get all the gm parts you need, pan, windage tray, pickup tube, dip stick and dip stick tube. Corvette pan may be possibly shorter but i believe it has side wings so it's not popular. Is your crossmember different? Do you have a torsion bar front end??
68c10airstream is offline   Reply With Quote
Old 12-01-2015, 08:54 AM   #4
The1960APE
The1960APE's Avatar
I am running the stock cross member with the torsion bar setup!
Old 12-09-2015, 12:42 AM   #5
crazy longhorn
Fabricate till you "puke"
I think that the LH8 pan should work for you....It will hang 1/2-3/4" below the cross member at the lowest point (you cant lay the frame with it), but on a lowered truck, it works. I have not done a 60-62....so working off info on my 69, I liked the fit (set in 3/4" ahead of the I6 spot), & the price was nice The only kink in the mix that I could see, is if the 60 cross member is taller up front, as compaired to the 67-72 pc ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-13-2015, 09:54 PM   #6
mooseknuckles
mooseknuckles's Avatar
f-body pan from summit
mooseknuckles is offline   Reply With Quote
Old 12-14-2015, 09:16 AM   #7
FarmerSid
FarmerSid's Avatar
FYI
http://www.superchevyperformance.com...p/12628771.htm
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
