Old 11-30-2015, 10:02 PM   #1
MJ1967
closed knuckle 4x4 to open knuckle upgrade donor list needed
Hi All,
Its been a while since i posted but i am looking to upgrade the front and rear differentials in my 68 3/4 ton and i need to know what donor years will work with minimal aggravation. However I'm sure this has been asked many times before.
I have located a 1985 with both diffs intact and once i hear confirmation it will work i will pull them from the yard.
Thanks in advance.
Mark in Pa.
MJ1967 is offline   Reply With Quote
Old 11-30-2015, 10:05 PM   #2
BCOWANWHEELS
Re: closed knuckle 4x4 to open knuckle upgrade donor list needed
1973 to 1987 gm axles. I,d suggest a dana 60 front kingpin ad a d60 or d70 (or 14 bolt rear)
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-30-2015, 11:35 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: closed knuckle 4x4 to open knuckle upgrade donor list needed
any 73-87 truck, 73-91 suburban front diff is a direct bolt in. you'll have to change your steering box, brake lines, master cylinder, proportioning valve. i'd recommend using a 69-72 steering column since it has a flex joint in the lower shaft and several companies sell the kit to install a later steering box. if you're going to swap the rear diff also you may have to move the spring perches and one shock mount. it sounds more complicated than it is. i've done a few and it can be easily done in a weekend if you have all the parts on hand when you start.. if you have any questions, shoot me a call after 4:30 calif time (925)642-5931
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-01-2015, 03:31 AM   #4
BCOWANWHEELS
also a dana 44 h/d is a nice front axle. it has disc brakes too.
Old 12-01-2015, 09:30 PM   #5
MJ1967
Thanks for the confirmation and help i am going to the yard this weekend to look around.
Old 12-01-2015, 09:39 PM   #6
BCOWANWHEELS
also if you want 6 lug you can get a set or 10 bolt or 10/12 bolt 1/2 ton axles.
Old 12-01-2015, 10:24 PM   #7
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I'd keep the eaton rear that your truck came with unless it needs brakes or isn't the ratio you want. They are very strong and yet not very heavy.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
