12-01-2015, 12:48 PM | #1 |
WTB 6 lug drum bare spindle
I have a 68 g20 van which is 6 lug and am trying to see if any of the c10 disc to drum brake parts will interchange with the van. I am looking for a 67-70 6 lug drum brake spindle. I don't need the hub just a bare spindle. maybe someone has one in there scrap pile. it doesn't need to be perfect. I just need it to compare measurements between my van and the truck one.
12-02-2015, 01:24 PM | #2 | |
Re: WTB 6 lug drum bare spindle
Do you need one in hand or just the measurements from one? I have a couple laying around. I can send you whatever measurements you may need.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
12-02-2015, 01:45 PM | #3 |
im sure i have one but its a complete drum assy with the spindle still in it. from my 67
1967custom |
12-03-2015, 12:10 AM | #4 |
I could use the spindle only. I don't need the drum or any brake parts or the hub just the spindle or knuckle as some call it. its only for a comparison use.
12-03-2015, 12:47 AM | #5 |
arnt g20,s 8 lug ?
I BELIEVE IN JOHN 3:16 |
12-03-2015, 01:10 AM | #6 |
no in the 67-70 chevy flat nose vans they introduced a g20 which was a 6 lug. it wasn't until 71 and up that a g20 was 8 lug. the 67-70 were still straight axle kingpin up front.
12-03-2015, 01:13 AM | #7 |
If I am not mistaken the G series vans ran a I-beam type axle. The pickup spindles of the same year will be totally different ( A arm type spindle) . You might want to compare the 55-59 I beam type spindles.
12-03-2015, 01:28 AM | #8 |
that may be another option, but I am just looking for the size and orientation of the bearings and the bolt pattern for the backing plate. I want to see if a 6 lug c10 disc brake conversion bracket will mount to my spindle.
12-03-2015, 01:55 AM | #9 |
I remember those leg crushing vans.
12-03-2015, 10:10 AM | #10 |
Ok. Looks like Chevytruckguy70 has everything you need .
12-04-2015, 11:32 PM | #11 |
Thanks to chevytruckguy70 I have a spindle on its way. I cant wait to do the comparison.
12-05-2015, 10:31 AM | #12 |
good luck Andrew let us know how you make out.....Merry Xmas
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
