Old 12-02-2015, 01:09 PM   #1
chanclas90063
chanclas90063's Avatar
Better Tranny
Good morning Group, I have a 1970 C-10 with a 350ci engine and 350 tranny. The tranny has been slipping and I was considering having it rebuilt but while I was at the mechanic's shop, he offered me a 400 tranny which he claims is better than my 350. I would appreciate any advice offered on this board. Much appreciated...
Larry
1970 Chevy Pickup C-10 Dodger Blue
305CI/Th400 auto trans
Long Bed/Rally Wheels
chanclas90063 is offline   Reply With Quote
Old 12-02-2015, 01:17 PM   #2
leftybass209
leftybass209's Avatar
Re: Better Tranny
Your 350 is most likely fine. The 400 is a stronger transmission, if you plan on throwing a lot of torque in the mix.
We would need more info about your motor, and your plans for your motor to truly tell you which would be better for your application.
leftybass209 is offline   Reply With Quote
Old 12-02-2015, 01:43 PM   #3
hamjet
hamjet's Avatar
Re: Better Tranny
I haven't checked but are they the same length? if not, more money for drive shaft change, plus are they going to make sure you have the correct speedo gear too?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-02-2015, 03:11 PM   #4
davepl
davepl's Avatar
Re: Better Tranny
TH350s were $75 twenty years ago, and while I have no idea what they're worth now, if you swap to the stronger 400 you'll run into crossmember and driveshaft length issues.
If your truck has the small floor hump, I'm not actually sure it'd fit in the truck.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-02-2015, 04:01 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Better Tranny
You will need to change the Driveshaft Yoke and probably adjust the lenght on it. Along with what is mentioned above how do you plan on getting the kickdown to work?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-02-2015, 04:43 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Better Tranny
TH400 trans is designed for the extra torque of a big-block. So yes they are stronger, but they also rob horsepower -- can't recall the exact number but I think I have read it's 40-50 HP. If you have a typical small block, the TH350 is plenty good as well as less expensive. If you're gonna change the trans anyway, why not upgrade to a 4-speed or OD trans?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-02-2015, 06:52 PM   #7
chanclas90063
Re: Better Tranny
Many thanks to this group for the responses. The engine is from a late 70s Camaro and according to my mechanic, is in good shape. I would like to put a little more power into the motor, but I prefer to find me a good mechanic locally that can advise me on upgrades. Anyway, based on the comments here, I think that I will forego the change of tranny and stick with the current 350. Thanks again folks, you responses are much appreciated...
Larry
Old 12-02-2015, 06:58 PM   #8
hugger6933
Re: Better Tranny
Your looking at uneeded expense to change to a 400 trans when a 350 will be plenty strong for what your gonna do.For the cost of the stuff needed to change it over to be right, you could have the 350 rebuilt. Jim
hugger6933 is offline   Reply With Quote
Old 12-02-2015, 09:17 PM   #9
chanclas90063
Re: Better Tranny
Thanks to you all, after reading the comments here, I made the decision to stay with the 350 and if I decide to change later, I will consider a 700R4. I appreciate all of the comments they came in handy in making my decision. Thanks all
Larry
Old 12-04-2015, 09:10 AM   #10
Re: Better Tranny
The TH350 is about as good as automatic transmissions ever got.
Old 12-04-2015, 11:49 PM   #11
BCOWANWHEELS
Re: Better Tranny
350th is tons better than the 700r4
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 12-14-2015, 04:24 PM   #12
chanclas90063
Re: Better Tranny
WOW!!! I am really surprised, I was told that the best tranny for my truck is the 700R4. Guess he was just trying to make a sale... Thanks for the info...
Larry
Old 12-14-2015, 04:42 PM   #13
MARKDTN
Re: Better Tranny
700R4 got a bad rep because of the weak front pump and some internals in the early ones. Then they got a bad rep for retrofits because people did not hook up or adjust the TV cable. There is nothing wrong with a good 700R4. It is the basis of the current 4L60E. If you use a 700R4 you must properly adjust the TV cable.
TH350 is an OK transmission. I would not swap to a TH400 just because I could get one cheap, HOWEVER the TH350 with some power in front of it will eventually grenade and when they go they basically self destruct. In your case with a stock engine, I would rebuild the TH350 that is there. If you later go to a blown 454, don't expect it to last forever.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-14-2015, 05:22 PM   #14
leftybass209
Re: Better Tranny
The best transmission for your truck is the one that suits your needs and driving style. If you do a lot of highway driving, and you like lots of low end torque for stoplight acceleration, then yes, an OD would provide the biggest benefit. Saying the 350 is tons better than the 700 is very subjective with no proof or comparison to warrant otherwise. A 350 is just a more user friendly transmission for those that don't know or want to know how to make a 700r4, or any other OD trans work correctly. When looking at transmissions, it's never cost effective to swap to or from one another to gain a particular trait, because the investment rarely ever nets a profit (mostly when talking about gaining gas mileage by swapping to an OD trans).
However, it can be beneficial when the original transmission is already shot. Time and time again we discuss the OD trans swap. It's too expensive to warrant the swap without the right rear gearing, and I never recommend dropping in a junkyard OD trans to save a dollar.
My truck came with a 700r4 when I bought it. Had it a Th350 when purchased I would never have made the swap unless the trans went out. I'd always suggest a comparison between the 2004r and a 700r4 when considering an OD trans because they are geared differently and one may benefit the owner more.
Since you've already considered keeping the 350, truck along with that idea. It's a cheap rebuild/replacement, and you know it already bolts right it. Best of luck!
Old 12-14-2015, 06:09 PM   #15
kehstr
kehstr's Avatar
Re: Better Tranny
a 700r4 is just a turbo350 with overdrive
kehstr is offline   Reply With Quote
Old 12-14-2015, 06:51 PM   #16
leftybass209
Re: Better Tranny
No, that is an inaccurate comparison.
gear ratios are as follows:
700r4 1st, 3.06, 2nd 1.62, 3rd 1.00, 4th 0.70, reverse, 2.29
TH350 1st 2.52, 2nd 1.52, 3rd 1.00, 4th x.xx, reverse, 1.93
Only 1 gear has the same ratio. The cases are shaped different, and there are different weights due to the difference in an extra gear.
A TH350 is 21 5/8" long with a 6, 9 or 12" tailshaft. A 700r4 is 24" long with a 6" tailshaft.
Old 12-14-2015, 06:53 PM   #17
kehstr
kehstr's Avatar
Re: Better Tranny
i stand corrected, but the general idea is that it's a 350 with overdrive
Old 12-14-2015, 09:23 PM   #18
Gimme Jimmy
Re: Better Tranny
The t400 is much tougher but the gearing is slightly higher.
Gimme Jimmy is offline   Reply With Quote
Old 12-14-2015, 09:59 PM   #19
jocko
jocko's Avatar
Re: Better Tranny
You can easily beef up the TH350 for a mild small block, if you feel the need. But, stock is probably fine. In your case, TH400 too much of a headache. If you don't mind extra work or paying for extra work - get a 2004R. Overdrive at approx. same length as TH350 (no driveline mods, just some trans tailshaft mount re-wickering). Your mechanic probably has a TH400 ready to go, perhaps that is why he's pushing for it. If he thinks it's the same amount of work to put in as the current TH350, I'd find another mechanic, then the transmission.
Old 12-14-2015, 10:35 PM   #20
Chrisbeds82
Chrisbeds82's Avatar
Re: Better Tranny
I have good strong 350 with a mild shift kit that I'm going to be taking out of my truck in the next couple weeks if you're interested. I was told it was just rebuilt a couple years ago and doesn't have many miles. Let me know. What area are you in? I travel a lot and may even be able to deliver.
Only pulling it out for an LS swap with a 4L80
Chrisbeds82 is offline   Reply With Quote
