Old 12-02-2015, 02:38 PM   #1
kenny4454
Power Steering Pressure Hose
I noticed my power steering pressure hose was leaking in my 67 Chevy C10. When I looked online for the hose it appears it is not available for this year. I am wondering how I determine which hose to purchase? Is there a way to identify what year the power steering gearbox is in my truck? Is the fitting on the end of the P/S pressure hose that goes into the steering box one that has an O ring fitting, or one that has a flange on each side? My lines appear to have flanges
kenny4454 is offline   Reply With Quote
Old 12-02-2015, 11:15 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Power Steering Pressure Hose
Don't know what you mean by "flanges" but unless the p/s box is from a later model, the fittings will be what is called inverted flare type. i do not have a part number for the hose, but if "correctness" is not an issue you can have one made. I made one at work for my '70 from all new components, but if your metal tube ends are good, they could be cut at the ends where they join the hose and be reused with a new hose section and flareless ermeto hose ends crimped on. I just used generic 90 degree hose ends and it worked just fine.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-02-2015, 11:20 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
Take the hose off and look to see if it's a flare fitting or an o-ring fitting. If flare get a hose for a 1968. If o-ring get one for a 1983.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 12-02-2015, 11:20 PM   #4
franken
What bit was leaking? Maybe something's loose/leaking...
Since 67 didn't have PS, pop the pressure (bigger if I recall) hose off the gear with a flare wrench and see if its a flare or O-ring.
Since its not stock regardless, some figuring may be required.
franken is offline   Reply With Quote
Old 12-02-2015, 11:32 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Take the hose off an go to a local auto parts store like a Napa. After 45 years who knows what has found it's way into these trucks.
Don't limit yourself to online only searches.
Edit... www.rockauto.com has them listed for all engine configurations for a 1967 C10.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-02-2015, 11:59 PM   #6
kwmech
Is it box steering or power assist steering? 67 had power assist available
Old 12-03-2015, 03:47 PM   #7
kenny4454
Thanks everyone for the help. Typo in the initial post with the word flange. I meant to say flare fitting. It appears to be box steering. My hose has a flare fitting and I have tried tightening down more and it still leaks right at the connection. I am guessing maybe the flare is worn out from being compressed? I just checked napas website and looks like they have a few for 1968. So going in with the old hose sounds like a good idea.
Old 12-03-2015, 05:09 PM   #8
Boog
laying low
Boog's Avatar
You will need to ask for a hose to fit 69-77 or so. Since 67's only came with a slave cylinder power assist any hose listed for a 67 will not work with your later model power sector. 69-78 or so used flared hose ends then in about 79 gm switched to oring fittings. Or you can take your old hose in and have one made.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
