Old 12-02-2015, 08:21 PM   #1
68Stepbed
68Stepbed's Avatar
Fresh air vent door knob ideas
I had to replace the foam on the fresh air vents in my 68. In the process, one the knobs or handles was cross threaded and when trying to reinstall correctly, it stripped out. I know I could just helicoil it or buy replacements, but I'm thinking of maybe having some custom knobs or handles made.
Has anyone made anything custom, and what did you do?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-02-2015, 08:45 PM   #2
68panelman
68panelman's Avatar
Re: Fresh air vent door knob ideas
Bet you could get some cabinet knobs to work.
68panelman is offline   Reply With Quote
Old 12-02-2015, 08:49 PM   #3
72c105speed
Snap-on stubby screwdriver handle, golf ball, c10 hotwheels, the options are limitless just matters how much time and money you want to put into it!
72c105speed is offline   Reply With Quote
Old 12-02-2015, 08:49 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fresh air vent door knob ideas
I didn't make them I just bought the same knobs as I installed on the dash.
Here is the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=662377
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-02-2015, 09:01 PM   #5
68Stepbed
68Stepbed's Avatar
The hotwheels idea is pretty cool! I was thinking stainless bullets, but it wouldn't match anything in my interior.
Matt
Old 12-02-2015, 09:04 PM   #6
68Stepbed
68Stepbed's Avatar
Here is the link.
Those look simple and clean!
Matt
Old 12-02-2015, 09:21 PM   #7
Andy4639
Old member
Andy4639's Avatar
Do a google image search. It will ull up all kinds of knobs.
Amazon.com: Hot Rod Machined Billet Aluminum Dash... Amazon.com: Hot Rod Machined Billet Aluminum Dash...
Old 12-02-2015, 09:38 PM   #8
68Stepbed
68Stepbed's Avatar
After some searching, I think I may like to have a simple cylindrical shaft that slides on, then a simple round knob that threads into the shaft facing forward and works as a set screw.
Matt
Old 12-03-2015, 03:20 AM   #9
toolboxchev
Black Delrin Plastic, or polymer material.
It is pretty tough stuff.
toolboxchev is offline   Reply With Quote
Old 12-04-2015, 08:43 AM   #10
Here's a couple knobs you probably don't want in your truck:
https://www.google.com/url?sa=t&rct=...XOSzcpFyn-nCxQ
Old 12-04-2015, 08:48 AM   #11
Grumpy old man
Grumpy old man's Avatar
Summit stocks a lot of nice dash knobs cheap.
http://www.summitracing.com/parts/cal-188400
Grumpy old man is offline   Reply With Quote
Old 12-04-2015, 02:16 PM   #12
toolboxchev
Those knobs have to ride in the back!
Old 12-04-2015, 02:35 PM   #13
Andy4639
Old member
Andy4639's Avatar
Tom is a member here he does nice work. May want to contact him.
This is his link
http://www.67-72chevytrucks.com/vboa...1&d=1388336272
