Old 12-03-2015, 12:27 AM   #1
1972RedNeck
1972RedNeck's Avatar
Higher Quality Turn Signal Switch
Working on a 1963 C60. The original turn signal switch was bad so I ordered a new one through Orange County Truck Parts (same parts as LMC, just cheaper). It worked great for about a month and then the self canceling cam broke. Now it has started to randomly make both rear lights flash.
Any where I can get a high quality turn signal switch?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-03-2015, 01:14 AM   #2
argonaut
argonaut's Avatar
Re: Higher Quality Turn Signal Switch
Classic industries! Buy the uber expensive OE type. It's worth it!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-03-2015, 12:47 PM   #3
1972RedNeck
Got a link? I see 1955 - 1962 and 1964 - 2002, but no '63. And '63 was a one-off switch.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-03-2015, 07:00 PM   #4
63burban
Chevy addict
I use Classic Truck Parts better switch, been lasting in some of my regularly used truck for years. http://www.classicparts.com/Switches/products/206/
63burban is offline   Reply With Quote
Old 12-03-2015, 07:18 PM   #5
sanford66
sanford66's Avatar
Yep, got one in my 66. Works perfectly. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 12-03-2015, 10:25 PM   #6
Fredthecat
1964-66 turn signal canceling cam (not entire turn signal switch) is:
Dorman part # 49308
$15 Amazon, NAPA etc.
Fredthecat is offline   Reply With Quote
Old 07-09-2017, 02:26 PM   #7
Shtudwn
The switch at Classic Parts for my 66 looks exactly the same as the one I got from the Truck and Car Shop. Worked fine for a bit then the contacts bent and started to flash constantly. I've taken apart and re-bent the contacts only to have them work inconsistently. The plastic parts on this are fine but the contacts are really cheap.
Does anyone have a real good quality turn signal switch that works?
Thank you.
Dan
Shtudwn is offline   Reply With Quote
Old 07-09-2017, 02:30 PM   #8
argonaut
argonaut's Avatar
See my lost above. #2.
I had the same problems with the aftermarket parts. Buy a GM version.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 07-09-2017, 02:40 PM   #9
Shtudwn
Thank you.
Would the Autowire one that is said to be "GM tooling" be a good one
https://www.summitracing.com/parts/a...s/applications
or the AC Delco one
http://www.rockauto.com/en/moreinfo....1321850&jsn=11
Any other links appreciated.
Dan
Old 07-09-2017, 07:18 PM   #10
vince1
From that list it looks like the expensive switch for a 63 is 53-507A. I think a C60 deserves a good one.
vince1 is offline   Reply With Quote
Old 07-10-2017, 12:57 AM   #11
'63GENIII
'63GENIII's Avatar
Gotta do mine too.
Not to hijack. Well kinda hijacking. Good to see ya here Jason. Hope all's well!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-10-2017, 06:44 AM   #12
ImpalaJim
ImpalaJim's Avatar
I bought a life time warranty 1 at O'reillys 9 years ago Borg Warner I do believe
ImpalaJim is offline   Reply With Quote
Old 07-10-2017, 09:29 AM   #13
Chevy Fleetside
Chevy Fleetside's Avatar
Originally Posted by Shtudwn View Post
Thank you.
or the AC Delco one
Dan
I put one of the Autowire ones in my truck about 3 years ago. No problems and still works great.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
