09-17-2003, 11:01 AM | #1 |
Is this bad for my posi?
I have the original tire that was used before the posi came in and it is bald. It is roughly 1 " to 1.5" shorter than the other three tires.
Now, is having a shorter tire in the rear with the posi bad for the POsi? Does it slip the clutches too much.
84 Silverado, |
09-17-2003, 11:21 AM | #2 |
www.73-87chevytrucks.com
1-1.5" shorter? Are you sure? Are the tires the same size and just worn. The BFG muds only have about 11/32" of depth on them and that is acceptable, but if the tires are THAT much different, I wouldn't run it like that too much.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
