Old 12-04-2015, 11:23 AM   #1
AJCK87
1997 GMC K1500 fuel pump and sending unit replacement
Hey guys,
I'm looking to do a drive way fuel pump replacement and I don't really want to drop the fuel tank or lift the box off. Since this is the second pump to go in less then a year... I wanted to cut an access port in the box to change out the pump. I was wondering if anyone had a good thread showing how they did it? Also wanted to get an idea of how big a hole and where it should be.
Thanks!
AJCK87 is offline   Reply With Quote
Old 12-04-2015, 12:24 PM   #2
b454rat
Re: 1997 GMC K1500 fuel pump and sending unit replacement
IMO can't replace without doing at least one. I did one to a 97 that I had, dropped tank but didn't lift box. It's a pain. I had to do it in my 96 I have now. Rusty lines makes it even more fun.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-04-2015, 12:28 PM   #3
Chris95GT
Lifting the box really isn't as bad as it seems, I did it myself in the driveway. I removed the rear bumper to make sure I didn't scratch the bed, then I just loosened the passenger side bolts, removed the drivers side bolts, and used a ratchet strap between the front and rear corners on the drivers side and my engine hoist to lift the drivers side up and hold it. It was easy to do by myself and way way easier than wrestling a tank around. Honestly, I didn't even break a sweat. IMO it's easier to do that then it is to cut a hole in the bed with enough access to get lines and such off, and the end result is nicer.
1991 C1500 ECSB - 5.3 LS 4L80E 14bsf - Gone but not forgotten
1999 C2500 GMT-400 Crew Cab Short Bed - 6.0 LQ4 - 4L85E
2003 Denali XL - Wifeys Ride
2008 K2500HD Duramax Sierra Crew Cab Short Bed - Daily
Chris95GT is offline   Reply With Quote
Old 12-04-2015, 12:32 PM   #4
Chris95GT
Here's the picture from the first time I did it, this is where I learned the hard way to take off the back bumper.
But seriously, if you have an engine hoist, it's easy.
Old 12-04-2015, 01:21 PM   #5
pwdcougar
pwdcougar's Avatar
Great write up and picture. I had to pay to have mine done (and I HATE paying) a few years back. The tank was just filled up and there was no safe way to drain 24 gallons out or lower all that weight.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-04-2015, 06:25 PM   #6
speedygonzales
speedygonzales's Avatar
I smell a cheap replacement part
What brand where the replacements, where did you get them and was it pump only or the entire sending unit?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 12-05-2015, 09:56 AM   #7
54 jimmy
54 jimmy's Avatar
I always pull the bed or lift the drivers side like said. never buy a cheap fuel pump learned that very quick. always replace with a ac delco or Delphi and never any issues. side note change your fuel filter just for good measure.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-05-2015, 01:56 PM   #8
91short
I cut a hole through the bed floor, I had to change it twice one year and just this year the wiring in the tank went bad so I had to pull it out again. My bed was starting to rust so I didn't care about cutting it, now it's so easy to get to. I do have a drop in liner so it's covered up and you cant see the hole when the liner is in place.
91short is offline   Reply With Quote
Old 12-09-2015, 12:26 AM   #9
AJCK87
Picked up a Delphi pump and sending unit, still one the fence about cutting the box or lifting it, thanks for the tips guys!
Old 12-09-2015, 12:27 AM   #10
AJCK87
Re: I smell a cheap replacement pump
Can't remember the brand of The last pump, thinking it was a cheap one. And it was just the pump no sending unit.
Old 12-09-2015, 09:08 AM   #11
speedygonzales
Most electrical parts should be ONLY OEM. The fuel pump is one of them. I never saw a cheap auto store pump last very long.
For others, don't change the pump only for a couple of reasons. One, the fuel level sensor is a wear item and should be replaced when ever the pump needs changed. Length of time not withstanding.
Two, there is a check ball in the sending unit that prevents fuel from draining back to the tank, causing long cranking time among others. If you only change the pump and not the sending unit, you chance having to go back in because of a sticking check ball.
Pride and joy
Old 12-09-2015, 09:42 AM   #12
Chris95GT
Slightly off topic, do you know exactly where this check valve is? I intend on replacing my pump only soon with a larger aftermarket, (actually pump and sending unit because I need a new one, but separately, LS Swap with extra fueling demands) and I want to make sure I don't accidentally eliminate it if it's somewhere that I'll be messing with.
Old 12-09-2015, 06:30 PM   #13
speedygonzales
The check ball is located in the housing between the pump and the top outlet.
Pride and joy
Old 12-09-2015, 06:35 PM   #14
Chris95GT
Thanks!
Old 12-12-2015, 12:26 PM   #15
AJCK87
If anyone is interested..... These are the measurements that I found on the net. I will be giving it a try. An port to access the pump fuel lines and electrical would have been an excellent factory installation. O well I'll make my own
Old 12-12-2015, 02:25 PM   #16
speedygonzales
Pop rivet a 2" metal strip underneath the hole extending into the hole a 1/2 inch all the way round to hold the piece you cut out. Paint the metal strip, rivets, edges of the hatch and think about further sealing the edge of the hatch with RTV after the paint dries.
I hope you don't come to regret cutting the hole.
Pride and joy
Old 12-12-2015, 09:42 PM   #17
AJCK87
Here's the access port for the fuel pump. I will be the most practical way for changing out the pump. Will post some pics of the hatch when it's done.
Old 12-12-2015, 09:46 PM   #18
AJCK87
Thanks for the tips. I was really on the fence about how to go about it. I don't have a garage or an engine hoist so it would have been difficult for me to lift the box. Plus I live on the north end of Vancouver island and its rainy season. The hole turned out pretty good and I'm going to brace the hatch
Old 12-12-2015, 11:34 PM   #19
68C15
blood type; Retumbo
68C15's Avatar
You're in Texas, he's in Canada. Us up north have rusty bolts and stuff to deal with.
Speaking of rust. I'd highly suggest dropping the tank. Then replace the metal brake line between the tank and frame. I see so many rupture behind the tank that I sell people a new brake line when I do a pump
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-13-2015, 08:41 AM   #20
Phillip Pennartz
The last time I replaced my fuel pump in my 97 c1500 with 4.3 and I have
replaced many over the years. The man at the parts counter told me that the
reason I was having fuel pump failures was because of bad design of connector
at the fuel pump housing. that plug was causing a voltage drop and that
was causing the pumps to go bad. The store was an O'Reilleys. He sold me a
pump and pump housing with improved connector and it came with a short
piece of wiring harness that you replace the factory plug with. So far this new
pump has about 10k mi on it
Phillip Pennartz is offline   Reply With Quote
Old 12-13-2015, 01:50 PM   #21
MrBillPro
MrBillPro's Avatar
Dropping the tank is not bad, it's just seems that I always have a full tank of gas when mine dies.
MrBillPro is offline   Reply With Quote
Old 12-13-2015, 05:34 PM   #22
speedygonzales
They always are full. The pump gets hot and boom fill it with a bunch of cold fuel. Seems when we did tanks they were always full.
On a pickup take the bed up. Gives you a chance to do other things too.
Pride and joy
Old 04-02-2019, 10:18 PM   #23
shifty
Questionable
shifty's Avatar
Question Re: 1997 GMC K1500 fuel pump and sending unit replacement
Bumping a really old [but related] thread to keep topics consolidated.
The high pitched whining from the fuel pump on my '98 has been driving me nuts for nearly a year now. I know, probably seems like I'm fixing everything in my truck right now, that's not lost on me! But I figure after a year, I should start ironing stuff out and I just got a bonus at work...
See mixed info online, like "whining on fuel pump means imminent failure, better replace it asap or get stranded!" then others say "all of the 95-98 C1500 OEM fuel pumps whined and it's totally normal!"
So I'm curious after reading this thread. Clearly the job will be a pain in the ass and I'm treading cautiously, asking questions. This specific statement caught my eye while reading up because I was looking at getting a Bosch 67381 to replace the OEM part...
I checked my three big local stores and - excluding off-brands - the name brands that keep coming up for my truck w/pricing are Bosch 67381 ($85), Delphi FG0086 ($145) or AC Delco MU1745 ($175).
For what it's worth the Delphi and AC Delco parts look damn near identical. Bosch's version looks similar to those two but way more robust and meaty.
Anyone in a position to help clear up some questions related to the topic/thread at hand? Like ...
Is a high pitch whine from the fuel pump really normal on a 21 year old truck with less than 90k miles? Never heard similar on my '03...
Realistically, will the Delco part outlast a very well known name brand like Bosch, and is there actually a difference between the Delphi and AC Delco part for a 97/98 5.7L C1500?
Any other helpful tips not already covered in this thread about the pumps? I'm cool on install, tank is only 1/8 full right now so I could potentially drop it this weekend....
Edit: Also found this tip from our resident expert
It's a good idea when ever possible to change out the module instead of just the pump since the gauge sending unit wears also.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-03-2019, 06:29 AM   #24
95 S_Trucker
95 S_Trucker's Avatar
Your 98 should have a big plastic sending unit/pump assembly with quick connect nylon fuel line ends. 97 was the last year for the metal sending unit with line nuts where you can replace just the pump.
The pump for your truck will look a lot different than the one pictured in this thread.
Edit: Your replacemt pump will also come with a new connector. You will have to cut off your old one and hook up the old one. If you get Delphi or ac delco, the butt connectors with built in heat shrink are ok to use. You can also solder and use heat shrink tubing to seal the splice from the elements. Don’t use standard butt connectors or rely on tape alone to seal the splice.
95 S_Trucker is offline   Reply With Quote
