Old 12-04-2015, 01:25 PM   #1
65standard
65standard's Avatar
Rear axle interchange?
Does anyone know if a 1999 suburban rear axle is the same width as my 1985 C/10. I see it has the same 5x5 bolt pattern. I'm looking for a rear axle with 3.73 posi for my LS swap.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 12-04-2015, 01:54 PM   #2
Rangerman
Rangerman's Avatar
Re: Rear axle interchange?
Ive been wondering also---
Im wanting to swap the 3:08 open end gears in a 79 to 3:73 with posi.
Rangerman is offline   Reply With Quote
Old 12-04-2015, 08:59 PM   #3
Speeding Dakota
Speeding Dakota's Avatar
Yes the axles are the same. I put a 3.42 posi out of a 90 burb under my 83 C10.
Speeding Dakota is offline   Reply With Quote
Old 12-04-2015, 09:04 PM   #4
68c10owner
68c10owner's Avatar
A 1990 burb is a different body style than a 1999 burb.
I beleive the 1999 burban will be wider than your truck rearend. THe spring pads may also be in a different place which isnt a big deal and the brakes may be different. It will work but there will be some differences to take into account.
Anthony
68c10owner is offline   Reply With Quote
Old 12-04-2015, 10:28 PM   #5
69heavychevy
69heavychevy's Avatar
It's not bolt on, different widths...
BTW GM production "posi's" don't hold up very well. Best bet is to add aftermarket gears and posi unit.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 12-04-2015, 11:03 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=373438
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-05-2015, 10:43 AM   #7
65standard
65standard's Avatar
I'm going to the junkyard now to measure the suburban' s rear axle.
Old 12-05-2015, 08:37 PM   #8
65standard
65standard's Avatar
The 1999 suburban rear is 65.5" drum to drum.
My 1985 C/10 rear is 65" drum to drum.
Old 12-05-2015, 08:39 PM   #9
68c10owner
68c10owner's Avatar
So its only .25 wider per side but the spring perches and shock mounts are in different locations. And the oem posi isnt very strong.
Anthony
Old 12-05-2015, 09:49 PM   #10
Gregski
Post Whore
Gregski's Avatar
good info ya'll
Gregski is offline   Reply With Quote
Old 12-05-2015, 09:54 PM   #11
65standard
65standard's Avatar
It might be a bolt-in rear. It has dual spring perches on each side. The inner perches might be for the earlier narrow frame?
For my situation, I'm going to cut off the spring perches anyways as I'm doing an axle flip.
Old 12-05-2015, 10:02 PM   #12
65standard
65standard's Avatar
My other choice is this 1990 blazer rear. Direct bolt-in, but it is a 6-lug wheel.
I did snag the blazer's cluster I needed for my LS2 swap and the tilt column.
Old 12-05-2015, 10:09 PM   #13
Tilt
I swapped a 90 model Suburban rear end in mine when I did the LS swap. 3.42 limited slip (Gov bomb). As long as you don't beat on it too hard, it should hold up for a while. For now, $150 for the burb rear beat the $1600 that Pyle Bros wanted to build mine.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 12-05-2015, 11:09 PM   #14
68c10owner
68c10owner's Avatar
The only difference between your 85 rearend and the blazer would be the 6 lug axles I believe. Should be able to do a direct swap of the 85 axles into the 90 housing. The 8.5 is pretty beefy. I know of a few 10 second turbo GN`s that still run a 8.5. If you need to rebuild anyway may as well upgrade to better axles.
Anthony
Old 12-06-2015, 08:58 AM   #15
mrolds88
In either 90 or 91 they upgraded from the 28 spline axles to the 30's. Worst case get your 4x4 rear get a set of Dorman axles and use your original brake drums.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-13-2015, 05:04 PM   #16
65standard
65standard's Avatar
Well I picked up the 1999 suburban rear axle with 3.73 gears and Eaton gov locker. Got it on trade for my flipped 1985 rear end. Good deal for me. I'll let you know how it works out.
I passed on the 1990 blazer rear as it was a 3.42 open.
Old 12-20-2015, 07:05 PM   #17
65standard
65standard's Avatar
Here us the 1999 suburban rear axle after I cut it out.
Old 12-20-2015, 07:14 PM   #18
65standard
65standard's Avatar
And after I stripped axle tubes clean. I will weld Mopar spring perches under the tubes for a flip and fabricate shock mounts.
This axle is only 1/2" wider overall, but it has 2 3/4" wide rear brakes. My original rear only has 2" wide rear shoes. A 3.73 locker rear with bigger brakes for my LSx swap.
Old 12-20-2015, 10:39 PM   #19
Gregski
Post Whore
Gregski's Avatar
I recall reading the same thing on this forum somewhere too, different widths, think the Burb is wider
Old 12-20-2015, 10:40 PM   #20
Gregski
Post Whore
Gregski's Avatar
Sounds like a plan, maybe you can find some wheels with a bit more of an offset to compensate for the 1/4 inch wideness on each side, or not, LOL
