Old 12-04-2015, 03:53 PM   #1
Koz1
Quick Question on rear hanger.
91 1500 Suburban 2wd,350tbi
Can i use the 73-87 c10 or Blazer lowered front hangers to gain some additional drop? or are the Suburban front hangers completely different?
Thank you
Koz
Koz1 is offline   Reply With Quote
Old 12-05-2015, 11:24 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Quick Question on rear hanger.
Haven't done that, but from what I've read, yes.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-05-2015, 01:48 PM   #3
Koz1
Yes to which question?
Thanks,i know this is the place to get the correct info,from some past experience from other part installers or builders.
Old 12-05-2015, 03:03 PM   #4
68Timber
68Timber's Avatar
Sorry about that. Yes, the hanger will give additional drop. I had to do some digging and read around a little. I figured if I shopped for Burb drop hangers you could compare the part numbers against the trucks but I couldn't find any listed for Burbs. I'm guessing that's why you're asking. What I found said the Burb frame was different but the hanger was the same as the trucks.
John
74 Honda Z50 build
Old 12-07-2015, 08:22 PM   #5
BaggedRanger
BaggedRanger's Avatar
Another difference is the front hanger for the rear from a 4wd.. The 4wd hanger hangs lower than the 2wd.. You will have to drill new holes but there are a couple that line right up..
BaggedRanger is offline   Reply With Quote
Old 12-07-2015, 08:25 PM   #6
68Timber
68Timber's Avatar
Yeah a few guys here have done that with a flip to have a nice static drop and not have to cut the floor.
John
74 Honda Z50 build
Old 12-08-2015, 12:56 AM   #7
BaggedRanger
Found this out when I had to swap frames.. I found a 4wd frame to replace my 2wd because it wasn't straight.. We went to go to put the 4 links back on and realized that the 4wd ones hung down below the 2wd ones.. Replaced witht he ones from my old 2wd frame..
Old 04-28-2016, 11:03 PM   #8
randomBullets
I know this is old post. But I need assistance.
You guys are saying use stock 4wd suburban shackles to lower a 2wd suburban?
Help me understand this. The longer the shackles the lower the truck will be?
Also I can do a flip? Without cutting the floor? I'd really like to see a step by step of this?
I'm gonna use 3" drop spindles in front. Maybe talk myself into cutting one coil off the spring?
Thanks.
randomBullets is offline   Reply With Quote
Old 04-29-2016, 07:51 AM   #9
68Timber
68Timber's Avatar
No. Actually we were discussing hangers, not shackles, but the answer is still no.
No. The longer the hangers, the further away the leaf springs will be from the truck and thus the taller the truck will be.
This is where the longer hangers come into play. If you do a flip without cutting the floor, it'll hit. But you can get around this by installing 4x4 hangers. They will add just enough clearance back so nothing hits.
Thanks.
Also, two more things. I haven't done any of this, just read about it here enough that I think I've got a decent handle on it. Also I need to point out that I can't recall reading about this working on a Suburban. I know a handful of guys have used the flip + longer 4x4 hangers on K5's but offhand I can't think of a Burb where I saw this done. But whatever you can think of, someone here has likely tried it. Search is your best friend.
John
74 Honda Z50 build
Old 04-29-2016, 09:10 AM   #10
randomBullets
so I need shorter shackles.
longer hangers if I do a flip.
Ok, more searching I'm sure someone has done it. Thanks for your help.
Old 04-29-2016, 10:09 AM   #11
68Timber
68Timber's Avatar
Longer shackles lower the truck. It helps to visualize the assembly and what each does to the location of the leaf spring.
John
74 Honda Z50 build
Old 04-29-2016, 01:51 PM   #12
randomBullets
OK. Longer shackles, will lower.
Longer hangers are needed for space when flipping the axle
Does anyone have any specs on the shackles? I'm sure there's a stock one from some vehicle that will do the job.
Anyone have any pictures of suburban flipped axle? What's sold in the kit you can't fab?
