Old 12-04-2015, 10:27 PM   #1
1rippen6
I6 power steering pump with brackets and pulleys
Removed this from an early 70's nova doesn't look the same as the trucks but appears that it mounts the same. It looks like the truck setup has 2 pulleys for the wp and 2 for the crank but this setup had an additional groove on both so I grabbed them encase the pump ran on them. The hoses were already gone and the pump spins fine but don't know if it works. Please make sure you know that it will work for your application because I will not. 125 shipped for everything. SOLD
1rippen6 is offline   Reply With Quote
Old 12-04-2015, 10:28 PM   #2
1rippen6
Re: I6 power steering pump with brackets and pulleys
last picture
Old 12-04-2015, 11:04 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Crank should not need a pulley. Damper should have 2 grooves.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-04-2015, 11:20 PM   #4
1rippen6
The damper did but it had an third groove(pulley) bolted to it.
Old 12-04-2015, 11:28 PM   #5
bigrigpardo
did you grab the 2 groove water pump pulley or just the extra third pulley? and did the alt have a double pulley?
bigrigpardo is offline   Reply With Quote
Old 12-04-2015, 11:46 PM   #6
1rippen6
I did grab the 2 groove water pump pulley and I didn't notice the alt. having a double pulley. I did zoom in on the picture I posted about 350% and it appears to be a single groove pulley but the picture gets a little blurry.
Old 12-05-2015, 12:44 AM   #7
bigrigpardo
would you do 100 shipped to nj? if so I will take it.
Old 12-05-2015, 12:45 AM   #8
bigrigpardo
and by chance was that nova an automatic with th350? I am looking for a proper kickdown linkage
Old 12-05-2015, 08:18 AM   #9
1rippen6
I will do that as long as you cover PP fees and I don't know if it was automatic or not but can check if I go again.
Old 12-05-2015, 10:15 AM   #10
70STOVEBOLT
The bolt on pulley for the crank and the extra pulley for the water pump are most likely for a/c.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 12-05-2015, 10:19 AM   #11
1rippen6
It wasn't an a/c car unless it was an add on piece but i didn't see any signs of that. There was a V8 a/c car there.
Old 12-05-2015, 10:33 AM   #12
bigrigpardo
payment sent
Old 12-05-2015, 10:36 AM   #13
70STOVEBOLT
Probably smog pump then.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 12-05-2015, 10:56 AM   #14
1rippen6
PP received will box up today should ship out Monday
Old 12-06-2015, 06:26 PM   #15
1rippen6
Boxed up and ready to ship added a few more pictures because I removed it from the brackets to get it in a medium flat rate box.
