12-05-2015, 01:51 PM | #1 |
65 Panhard bar placement
Right side of differential has large casting where end of bar bolts. Other end goes slightly down to drivers side frame. Ive lowered about 6in and need to remount on frame. Set it at height and mount bracket o frame where it wants to go?Seems ljocation has moved out and back about an inch.
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. |
12-05-2015, 07:45 PM | #2 |
Never Ending Projects
Re: 65 Panhard bar placement
Yep, lower you go, more the bar will shift. Put the bracket in the factory location and buy an adjustable one.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-05-2015, 08:57 PM | #3 |
and then i adjust till frame si equal distance to first groove in tire? I centered it thenheated and bent.(i know) my own springs. Had to keep turnming them until they lined up straight up and down. tool off all clamps and it sits epual distance from brake drum.If you find your seld beating spring into place with 12lb beater, well when you relax that spring wil through frame where it eants to.
12-06-2015, 01:34 AM | #4 |
Ummm... okay....
12-06-2015, 10:29 AM | #5 |
Yea not sure what all that means. But for a setup that low I would put a long panhard bar on it. Solves a lot of issues.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-02-2016, 02:24 PM | #6 |
But Found Her 25yrs Later!
What long adjustable track bar do you guys recommend?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-02-2016, 08:02 PM | #7 |
Why Porterbuilt of course!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-03-2016, 12:50 AM | #8 |
X2 on the porterbuilt panhard bar.
Just got mine installed last friday. |
01-03-2016, 06:32 PM | #9 |
I have early classics super track bar on mine. Works well and I like the urethane bushings over the rod ends for a daily driver.
Jimmy
01-03-2016, 06:41 PM | #10 |
Does the PB bolt right up to the 60-62 frame?
01-03-2016, 09:08 PM | #11 |
why not a watts link I have a friend that builds custom frames and that's all he uses so no matter how high or wow low the dif is always center
01-03-2016, 09:27 PM | #12 |
I welded mine in, and the bar goes to Porterbuilt arms. But brackets for stock arms are available.
http://pbfab.com/shop/trac-bar-kits
01-03-2016, 09:33 PM | #13 |
Test fit.
