![]() Join Date: Oct 2008
Rear Differential Casting Number -- How to Decode??
Hello,
I've searched here on the forum and also on the interwebs... But there doesn't seem to be any info on how to decode our truck rear axle casting numbers... And also what the casting numbers tell us. Forgive me if the info is here, but again I searched and couldn't find -- Anyway, the casting numbers on my rear axle are as follows -- NF3896888 GM 59 Thanks for the help!! ![]() |
Re: Rear Differential Casting Number -- How to Decode??
Sounds like a 3.55 from a Chevelle, but hard to say. Are you sure this is out of a truck? Can you find the 3-letter code?
#3 | |
I'll look tomorrow for the 3 letter code. Just curious as to what the casting # says |
Not much. If you really want to know what gear ratio your truck came with and what sort if any traction device it has, just change the fluid. Chances are the 50 yr old truck needs a fluid change anyhow.
Bump. Anyone?
Thanks! |
Code is --
RHA W238 2 I believe this is a '72 3.07 rear and is original to the truck |
#7 | |
The Older Generation
You would be correct. Here are the ratio charts: http://67-72chevytrucks.com/vboard/s...d.php?t=578793 LockDoc
#8 | |
